Author Topic: Ultimarc Tri-Sync Utility for use on TV  (Read 2421 times)
lettuce
  • Make It So!
« on: August 02, 2006, 11:47:09 am »
Can i use the Tri-Sync Utility on my Toshiba TV, as im not to sure what Khz TV's can safely go up to? Using the Tri-Sync Utility it allows the AVGA card to display 31khz non-interlaced picture, just woundered if this would sort out a display problem i seem to be getting with my TV, where the picture will shake/flicker by very small amounts
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
Re: Ultimarc Tri-Sync Utility for use on TV
« Reply #1 on: August 06, 2006, 07:46:54 am »
If you are using an RGB SCART-connected TV then the tri-sync util should not be run, it will not work.
Andy
lettuce
  • Make It So!
« Reply #2 on: August 06, 2006, 08:51:54 am »
Ok, thanks for the reply.
