Author Topic: Atomic FE layouts  (Read 2630 times)
divemaster127
  • Trade Count: (+60)
  • Last login:December 02, 2018, 08:05:08 pm
  • My webstore is arcadeemulator.net
    • arcadeemulator.net
Atomic FE layouts
« on: August 01, 2006, 03:50:25 pm »
I have been running other frontends im wanting to give Atomic FE a try, a lot of the layouts are 640 X 480, is there anyway simple to change these over to 800 x 600, this is the res I run on my betson
thanks
dm
I carry both ultimarc & happ items, all brand new & I ship from the united states. My online store is ARCADEEMULATOR.NET, pm if I can help in anyway.
youki
  • Last login:October 12, 2025, 12:33:39 pm
  • Atomic Front End Creator
    • Atomic Front End
Re: Atomic FE layouts
« Reply #1 on: August 02, 2006, 03:02:53 am »
Hi,
What ever the resolution you are using, Atomic will adapt the Layout for you. (by strechting).  So you can use a 640x480 layout in 800x600 resolution.   (but there is no real interrest to use a 640x480 layout in 800x600 because it won't be nicer , just consume more memory).
Or you can try to adapt yourself the layout to 800x600 ,  open it with AtomicLayoutEditor , go to layout\properties , change the resolution to 800x600 , resize or change image you need  and adjust fonts as you want.
