Author Topic: Disconnecting low voltage power from Jamma cabinet  (Read 1467 times)
edge
  • Last login:May 08, 2025, 09:08:47 am
  • AttractMode and GroovyArcade rock!
« on: July 31, 2006, 11:08:35 am »
Here's my situation:
- I have a SmashTV Jamma+ cabinet.
- I would like to connect the cabinet to both the JPAC and AVGA card.
Before I do something foolish, I would like to confirm that I am on the right track...  ;-)
Please review my attached pics.  How do I disconnect the low voltage power?
Thanks for the help!
Edge
« Last Edit: July 31, 2006, 08:35:22 pm by edge »
SirPeale
  • Green Mountain Man
Re: Disconnecting low voltage power from Jamma cabinet
« Reply #1 on: July 31, 2006, 08:38:53 pm »
Remove the AC wires from that power supply, and wrap electrical tape around the terminals so it doesn't short out on anything.
edge
« Reply #2 on: July 31, 2006, 09:01:27 pm »
Peale,
Thanks for the reply.  However, I am unsure about which wires you mean.  I am not trying to be difficult - just want to be sure.
I circled 2 possible interpretations in red (thanks, krick!).
Survey says.... ? ? ?
« Last Edit: July 31, 2006, 09:03:20 pm by edge »
westell
  • Last login:July 09, 2010, 06:43:07 pm
« Reply #3 on: July 31, 2006, 09:12:18 pm »
Pull the quick diconnect apart and tape it
edge
« Reply #4 on: July 31, 2006, 11:00:46 pm »
Thanks.  Will do.
Edit:  I disconnected the molex circled in red on bottom of screen.  Worked fined.  I am up and running with the JPAC and AVGA.  Thanks for the help.
« Last Edit: August 01, 2006, 01:10:34 pm by edge »
