Author Topic: More problems  (Read 2347 times)
20eyes
  • Last login:July 01, 2009, 05:41:10 pm
More problems
« on: July 29, 2006, 08:54:30 pm »
I did some work on my galaxian cabinet and I just put everything bak in the cab and now I get no picture. The only thing I can think of is I may have bumped one ofthe pots. I adjusted the pots and still get nothing. So I adjusted the focus and now all I can get is various degrees of a blank green screen.
grantspain
  • Last login:July 11, 2025, 05:26:50 pm
Re: More problems
« Reply #1 on: July 30, 2006, 06:48:48 am »
sounds like the input signal is missing ,what work did you do on the cab?
Ken Layton
  • Guru
  • Technician
Re: More problems
« Reply #2 on: July 30, 2006, 12:14:12 pm »
Did you remember to plug in ALL the cables?
20eyes
Re: More problems
« Reply #3 on: July 30, 2006, 10:06:22 pm »
I never unplugged the cables, except the light and the speakes the rest i left all together and pulled everything out at once.
I'll have to check for loose connections and start there it cant be too complicated, it worked before.
Level42
Re: More problems
« Reply #4 on: December 23, 2006, 03:26:40 am »
Old thread, but I'm curious if you fixed it and also what serial nr. does your cab have ? What monitor is in it ? I've bought a Galaxian last monday, check out http://forum.arcadecontrols.com/index.php?topic=61246.0 for a lot of info and pics....
