Author Topic: MAMEWAH 1.61 won't work on a clean install - bombs on generating game list  (Read 1672 times)
MartyNg
  • Last login:April 26, 2014, 11:37:48 am
I've had this working at one point, and when it stopped working, I would do a reinstall of MAME/MAMEWAH, and it would start working again. However, that strategy is not working any more. Now I get this error when I try to generate the games list from within MAMEWAH 1.61. (Win98SE)
8/1/06 10:38:54 AM MAMEWAH launched
8/1/06 10:38:54 AM Desktop colour: 10841658
8/1/06 10:38:54 AM Wallpaper filename:
8/1/06 10:38:54 AM Display mode: 1024x768 @ 0Hz, 16 bit colour
8/1/06 10:38:54 AM Decimal symbol: '.'
8/1/06 10:38:54 AM Games list read: mame-0.lst
8/1/06 10:38:55 AM Layout selected: C:\MAMEWAH\layouts\Classic 640x480\layout.lay
8/1/06 10:38:55 AM Ctrlr file selected: C:\MAMEWAH\ctrlr\default.ini
8/1/06 10:39:13 AM Commandline run: COMMAND.COM /c c:\MAME\MAMEPP.EXE -listxml|xml2info > C:\MAMEWAH\MAME.DAT {flags=17}
8/1/06 10:40:11 AM Error: 62 Input past end of file in ReadDAT
8/1/06 10:40:11 AM Error: 55 File already open in GenerateList
8/1/06 10:40:11 AM Games list read: mame-0.lst
8/1/06 10:42:46 AM Error: 55 File already open in INI_SaveConfig
8/1/06 10:42:46 AM Error: 55 File already open in EMUINI_SaveConfig
8/1/06 10:42:46 AM Error: 55 File already open in LISTINI_SaveConfig
8/1/06 10:42:46 AM MAMEWAH quit
Any ideas what this means? (The 1.62 beta working, but only on my PC monitor...still trying to figure out this powerstrip program) 1.61 Loads on my Arcade monitor but not my PC monitor (although the game list generation bombs.  I would use 1.62 if I could figure out what I did wrong with powerstrip.
Thans for any pointers!  :)
« Last Edit: July 29, 2006, 12:05:24 pm by MartyNg »
MKChamp
  • Last login:December 24, 2025, 01:30:45 pm
  • Stil around.
If you are using MAME .107, see this thread...
http://forum.arcadecontrols.com/index.php?topic=56050.0
MartyNg
Cool. I tried that XMLInfo file, and that worked. However, a lot of my games wouldn't start up in MAME .107. I simply reverted to .106 and everything seems to be working again. Thanks!
Your roms probably need updating...
