Author Topic: Introducing Project 42! Miniaturization in Motion - Final(?) design  (Read 14361 times)
TOK
  • Last login:Yesterday at 04:06:57 pm
  • The Game Always Wins
Re: Introducing Project 42! Miniaturization in Motion - New design
« Reply #40 on: June 17, 2007, 07:16:00 pm »
I'd take advantage of the LCD's size and round some edges, and also make the base thinner.
Whatever design works for you is fine, but you have a ton of advantages using the flat profile of an LCD.
Dreamwriter
  • Last login:August 28, 2010, 04:33:09 pm
  • Sleep is for the weak!
    • Games of Yore
« Reply #41 on: June 17, 2007, 11:23:14 pm »
There'll be a couple curves in there, I just didn't want to (or need to) go to the effort of modelling them.  As for the base size, that's the smallest it could be from the old design - I could probably make it a bit thinner (lower) now that it's a lot wider (everything doesn't have to be stacked on the motherboard anymore), but I do like the idea of being able to space things out and have lots of "breathing" room.  The old setup was incredibly packed - here, check it out:
Note, those speakers at the bottom are new (since the old speakers were built-into the screen), they don't fit inside the case, and are the reason for the first rise above the control panel on the new design.
TOK
« Reply #42 on: June 18, 2007, 06:58:25 am »
Perhaps make the cabinet deeper and mount some of the stuff on the door behind the monitor.
Dreamwriter
    • Games of Yore
« Reply #43 on: June 22, 2007, 04:58:12 am »
For fun tonight I threw together yet another new design, this time a lot closer to my original design (the base is the same size as the prototype base, except made of 3/4" thick wood):
and the screen can rotate to vertical orientation:
That ring on the front is my crappy representation of the TT2 steering wheel :)
So what do y'all think?  Which should I go with, this new design or the last one?
stephenp1983
  • Last login:March 24, 2024, 11:26:39 am
« Reply #44 on: June 22, 2007, 08:12:14 am »
Is the circle on the front a weight to keep it level?  I like the second design much better, and it also gives you the ability to change from vertical to horizonal.
stuckpixel
  • Last login:March 15, 2016, 02:59:23 pm
« Reply #45 on: June 24, 2007, 12:27:05 am »
I like the rotate-able from horizontal to vertical.
Dreamwriter
    • Games of Yore
« Reply #46 on: June 24, 2007, 05:09:36 am »
Alright, here it is the final design, tell me what you think.  This is really just the original prototype design, made from 3/4" chunks of wood (oh, and I finally put the marquee on top).  I really liked the small size of the prototype, and I found another screen like it had the first time, this time I'll be a bit more careful, not take the screen out of its case (there wasn't really need to do that last time).  Now I can order the screen, buy some wood, and corral my woodworking friend and get some real work done!
stephenp1983
Re: Introducing Project 42! Miniaturization in Motion - Final(?) design
« Reply #47 on: June 24, 2007, 09:39:14 am »
lol I guess I should have read :).  Anyway I like the design, and I think the steering wheel will be a neat addition to it
danny_galaga
  • Last login:Yesterday at 10:29:24 pm
    • dans cocktail lounge
« Reply #48 on: June 27, 2007, 04:04:02 am »
thats HUGE! where will you put it? or are you going to live in it  ;D
