Author Topic: Pac Reunion stick with Tornado Terry shafts  (Read 2047 times)
brophog
  • Last login:January 20, 2019, 03:49:41 am
« on: July 26, 2006, 03:59:40 pm »
I know several people on here use these sticks. I've decided my t-stiks aren't cutting the mustard anymore for me after 6 months of use. I want to put in a dedicated 4-way stick and have become accustomed to the reunion stick through use at a local pizzaria.
The idea of using Terry's longer shafts is simple: I don't want to top mount and use lexan. Has anyone that has installed these longer shafts into a wood panel noticed a difference in feel from the original setup?
Lutus
  • Last login:August 23, 2012, 10:58:10 am
  • "I love my Power Glove. It's so BAD!"
Re: Pac Reunion stick with Tornado Terry shafts
« Reply #1 on: July 27, 2006, 08:44:55 am »
This has been discussed in numerous threads.  This thread as well as many others... (search for "reunion tornado terry") will get you started.
http://forum.arcadecontrols.com/index.php?topic=34739.msg301856#msg301856
www.justin.tv/lutus8
www.encoreinstruction.com <-- for my fellow musicians
RobotronNut
  • Last login:December 22, 2018, 11:39:19 am
« Reply #2 on: July 27, 2006, 02:10:58 pm »
the tornadoterry shaft + 1 3/8" ball is around 3/4" to 7/8" longer than an unmodified reunion. this will mean that your hand will have to travel farther to engage in any given direction (i.e. there is a larger "dead zone" in the middle).
i use the tornadoterry and like it, but i haven't directly compared it to the stock reunion (my panel is wood, and the stock reunion is just too short).
to see my "Frankenpanel" and design notes, click here.
brophog
« Reply #3 on: July 27, 2006, 03:22:50 pm »
Thanks robotron. That's the kind of thing that's not in any of the searches.  :cheers:
At any rate, the missus seems to have something against the color red. Looks like I'll use a versa-ball instead.
RobotronNut
« Reply #4 on: July 27, 2006, 05:08:11 pm »
i avoided the versa-ball, because it's 1/2" to 3/4" longer than the tornadoterry. i think this will have a negative impact on game play.
mcmaster-carr carries many types of ball knobs that fit. there are some example part numbers on the web page referenced in my signature. besides the bright red polypropylene, there is a shiny black phenolic, a red phenolic (which is a dark burgundy/maroon color), and a plain aluminum (which is very nice but only comes in 1" diameter, which is too small for my taste).
brophog
« Reply #5 on: July 27, 2006, 06:29:02 pm »
Thank you very much! I wasn't aware those balls were swappable.
RobotronNut
« Reply #6 on: July 27, 2006, 07:26:58 pm »
when i bought mine, they were simply threaded shafts, with no ball tops. you could use the ball top from your reunion (but recent reunions seem to have non-removable ball tops) or get one from a local hardware store or mcmaster-carr.
i see they now come with a ball top. i assume they are still swappable, but you should probably verify that with tornadoterry.
Kremmit
  • - AHOTW -
  • Who the heck is that?
« Reply #7 on: July 28, 2006, 12:10:11 am »
You can shorten a Versa-Ball easily, just dremel new e-clip grooves at the desired height.
Lutus
« Reply #8 on: July 28, 2006, 08:20:47 am »
I stand corrected... I apparently was unaware as to the information you wanted. ;)
