Author Topic: What's this Happ joystick like?  (Read 4375 times)
Homer
« on: April 01, 2002, 02:53:53 am »
50-9970-00
H.D. Joystick, Trigger only
50-9980-00
H.D. Joystick, w/1 Fire Button
Heavy Duty 8-Way
Trigger Joystick
It looks like the Tron stick but I'm wondering about the tightness/feel of it. Anyone have one of these? Thanks for any info!
Lilwolf
  • Last login:June 08, 2026, 09:58:06 am
Re: What's this Happ joystick like?
« Reply #1 on: April 01, 2002, 09:54:07 am »
I have a used one and it feels just like the tron sticks.  But I'm not running them next to each other (so in my mind, they are 100% the same).
Homer
« Reply #2 on: April 02, 2002, 01:30:20 am »
Thanks lilwolf! Does it take up much more space (internally and externally) than a HAPPS super? I know the trigger must add an extra switch right? Was going to replace one of normal HAPPS sticks with one of these. Thanks!
Lilwolf
« Reply #3 on: April 02, 2002, 03:44:22 pm »
its a lot taller and maybe twice the size below.  I can't remember if it uses the same screw holes.  the contol panel thats in doesn't have any joysticks in it.
btw, it sucks for most things.  I would ONLY use it for some games.  I use it like this
joystick - trackball - buttons
so I can use the joystick with my left hand and the trackball for games that need a joystick, trackball, and a trigger button.
or I use my trackball and buttons for most other games.
ie, its good for ikari warriors type games and tron and zaxxon style games)
Homer
« Reply #4 on: April 03, 2002, 12:17:47 pm »
Yeah I only wanted one to use for Tron, Forgotten Worlds, Discs of Tron, and Ikari Warriors.
Defender
Hmmmm
« Reply #5 on: April 04, 2002, 08:38:21 pm »
I wonder if the slikstik guys could replace the 4-way stick with one of these babies?? May not be enough room. Does the trigger on this thing need a standard button switch underneath or is it something different?
Q-bit
« Reply #6 on: April 07, 2002, 06:55:55 pm »
Good question! And with the Oscar plates now available, the dedicated 4-way stick may not be needed on the slikstik. But a stick with a button is necessary for many games (some you mentioned).
SlikStik-Christian
  • Last login:November 04, 2004, 10:28:08 pm
  • Gaming will never be the same...
    • SlikStik Arcade Controllers
« Reply #7 on: April 07, 2002, 08:27:00 pm »
=Defender=
Yes  ;D we can in fact change the 4-way in the middle of the SlikStik to accommodate the Happ Heavy Duty Trigger Stick.
If you would like more info, or want to discuss this further, feel free to contact us at: info@slikstik.com
Happy Gaming...
Christian
Thank You
Christian
SlikStik Customer Support
http://www.slikstik.com
The Worlds Best Arcade Controllers
