Author Topic: Ghosts'N Goblins  (Read 3008 times)
romid
  • Last login:November 17, 2008, 02:33:12 pm
  • MAME rox your socks!
    • Temp MAME pics
Ghosts'N Goblins
« on: March 12, 2003, 12:40:44 am »
Anyone able to continue when playing ghosts and goblins?
It gives me the option to continue, but regardless of what button I hit, it doesnt continue (even if there are enough credits)
Also, I have a 1.67Ghz athlon using XP and Im getting about 20 out of 60 fps ...is that how it should be or am I missing something?
jets
  • Last login:February 25, 2005, 06:40:39 pm
  • all your base are belong to us
Re:Ghosts'N Goblins
« Reply #1 on: March 12, 2003, 01:34:01 am »
That thing should be runnnin at the full 60fps. Disable everything and only enable color & res switching, throttle, force aspect ratio. If it doesn't run smooth then I don't know what to tell you.
romid
    • Temp MAME pics
Re:Ghosts'N Goblins
« Reply #2 on: March 12, 2003, 01:40:33 am »
This is where its at right now:
C:\mame>mame -showconfig
###  mame running parameters ###
### Frontend Related ###
clones                  1
### Windows path and directory options ###
rompath                 roms
samplepath              samples
inipath                 ini
cfg_directory           cfg
nvram_directory         nvram
memcard_directory       memcard
input_directory         inp
hiscore_directory       hi
state_directory         sta
artwork_directory       artwork
snapshot_directory      snap
diff_directory          diff
ctrlr_directory         ctrlr
cheat_file              cheat.dat
history_file            history.dat
mameinfo_file           mameinfo.dat
### Windows video options ###
autoframeskip           1
frameskip               0
waitvsync               0
triplebuffer            0
window                  0
ddraw                   1
hwstretch               1
resolution              auto
refresh                 0
scanlines               0
switchres               1
switchbpp               1
maximize                1
keepaspect              1
matchrefresh            0
syncrefresh             0
throttle                1
full_screen_brightness   0.000000
frames_to_run           0
effect                  none
screen_aspect           4:3
sleep                   1
rdtsc                   0
### Input device options ###
mouse                   0
joystick                0
lightgun                0
steadykey               0
keyboard_leds           1
a2d_deadzone            0.300000
# ctrlr                 <NULL> (not set)
### Mame CORE video options ###
norotate                0
ror                     0
rol                     0
flipx                   0
flipy                   0
debug_resolution        auto
gamma                   1.000000
brightness              1.000000
pause_brightness        0.650000
### Mame CORE vector game options ###
antialias               1
translucency            1
beam                    1.000000
flicker                 0.000000
intensity               1.500000
### Mame CORE sound options ###
samplerate              44100
samples                 1
resamplefilter          1
sound                   1
volume                  0
### Mame CORE misc options ###
artwork                 1
use_backdrops           1
use_overlays            1
use_bezels              1
artwork_crop            0
artwork_resolution      0
cheat                   0
debug                   0
# playback              <NULL> (not set)
# record                <NULL> (not set)
log                     0
oslog                   0
skip_disclaimer         1
skip_gameinfo           1
### Configuration options ###
readconfig              1
verbose                 0
anything you see that I should change?
u_rebelscum
  • You rebel scum
    • Mame:Analog+
Re:Ghosts'N Goblins
« Reply #3 on: March 12, 2003, 02:15:32 am »
autoframeskip           1
sleep                   1
Disabling these two should increase speed, depending on your exact MB.  There's other options, but try these two first and report back if it doesn't work.
Robin
Knowledge is Power
romid
    • Temp MAME pics
Re:Ghosts'N Goblins
« Reply #4 on: March 12, 2003, 03:11:32 am »
Sweet!!  perfect 60/60
Thanks for your help guys!
