Author Topic: Ms Pacman: Do I need to remove the PCB to install a speed up chip?  (Read 1283 times)
dndcollect
  • Last login:September 18, 2007, 09:09:54 pm
i have a bootleg ms pacman jamma board. I just got a speed up chip from Mikes arcade. The instructions say to remove the board.
can I just install the chip or does the board have to be disconnected?
I just want to make sure I dont mess up my board, etc.
Thanks.
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
Re: Ms Pacman: Do I need to remove the PCB to install a speed up chip?
« Reply #1 on: July 20, 2006, 12:31:44 pm »
Mikes' sells a speedup chip for a bootleg board ? Is the boot board chip-compatible with the original ?
This is a genuine queston as I am thinking of putting a bootleg in my current Pac project.
Cheers.
Working: Not Enough
Projects: Too Many
Progress: None
dndcollect
« Reply #2 on: July 20, 2006, 12:37:14 pm »
its entirely possible that it does not work on a boot board. i took a gamble. i just mentioned that in case there are different chips out there.
« Reply #3 on: July 21, 2006, 03:26:19 pm »
You should definitely at least disconnect the board from the power supply.
