Author Topic: Any ideas on how to remove a stripped allen head set-screw...  (Read 4106 times)
MaximRecoil
...from the knob of an SNK LS-30 rotary joystick, without damaging the knob or the threads that the 2mm set-screw is in?
« Last Edit: July 18, 2006, 10:37:49 am by MaximRecoil »
Ken Layton
  • Guru
  • Technician
Re: Any ideas on how to remove a stripped allen head set-screw...
« Reply #1 on: July 18, 2006, 10:49:51 am »
A broken screw extractor.
MaximRecoil
« Reply #3 on: July 18, 2006, 11:53:34 am »
Unfortunately that didn't work. The set screw is too short for the extractor to get a grip on it. Does the knob have to come off to change the microswitches on an LS-30? I assume it does. Maybe a machine shop could get that set screw out (which would probably carry a ridiculous price tag with it); but I can't; not without destroying the knob anyway. Very irritating...
D_Zoot
  • Last login:November 18, 2010, 03:59:37 pm
  • Sorry if I get any spit on you...
« Reply #4 on: July 18, 2006, 12:20:03 pm »
Maxim,
This on the Dynamo cab?  If it is, and you get stuck on it, bring the stick back to me and I'll swap it for another.
D
MaximRecoil
« Reply #5 on: July 18, 2006, 07:44:25 pm »
Maxim,
D
You have another LS-30? If so, that'd be great, thanks.
I'll let you know.
D_Zoot
« Reply #6 on: July 18, 2006, 08:37:33 pm »
I should.  Let me know if that set screw just isn't going to come out at all and I'll dig around.  I think I've got one or two of those in a box somewhere.
D
MaximRecoil
« Reply #7 on: July 18, 2006, 10:07:46 pm »
Yeah, that set screw is going nowhere any time soon. Let me know if you can find another LS-30. Most LS-30's don't even have set screws for the knob; only the very early ones do. The 2nd player LS-30 on that Dynamo cab is the more typical later version with the center cap and no set-screws.
D_Zoot
« Reply #8 on: July 20, 2006, 08:54:10 am »
Yup, found one.  It's the later type, no set screws.
I'll be away this weekend, so if you want to swing up to the shop first of next week I'll hook you up.
D
MaximRecoil
« Reply #9 on: July 20, 2006, 09:54:34 am »
That sounds good.
I'm going to have to bring the whole control panel down to you though because I have no idea how to get that stick out of there without being able to remove the knob, or even if it is possible for it to come out without removing the knob. It is a shame to destroy the knob on it to get the stick out of the CP but is there any other option?
Also, do you have a rotary switch wire harness to go with the LS-30 you found? The one that is already there can't be reused on the replacement stick because each wire is soldered directly to the pins on the rotary switch, instead of having a connector like the later LS-30's have.
D_Zoot
« Reply #10 on: July 20, 2006, 11:46:59 am »
Yup, the harness is already on it.
Sure, bring the whole panel.  I'll get it off,  in one piece or two..... or three, or four...   :)    It's a shame to wreck it, I know, but it's no good the way it is!
D
