Author Topic: What router bit did this cut?  (Read 1326 times)
« on: July 17, 2006, 08:45:14 pm »
I was pointed to Bones cab to see how he did the routing around his trackball. I was curious if anyone knew if this was a 45 degree chamfer bit that made this?
DrewKaree
  • HAH! Nice one!
    • A lifelong project
Re: What router bit did this cut?
« Reply #1 on: July 17, 2006, 09:51:44 pm »
I believe you're referring to the white area that's been routed.  The answer to that should be "yes, it was done with a chamfering bit" (although I think he may have used a 30o bit for that)
They make several different angles, obviously, and it'd benefit you to use a jigsaw (or circ saw) to determine what angle you'd prefer, then buy the bit that has the angle you want to achieve.
« Reply #2 on: July 17, 2006, 10:30:11 pm »
Great info! Thanks sir Karee
