Author Topic: I checked but... Still a Question for Randy - Wiz49 - No ID  (Read 3428 times)
MYX
    • MYX Digital Blog
Hey Randy, on the site you said use device #1 if it is your first device and 2,3,4 for additional ones. I bought 2 for my 2 49 ways. How do I know which is the #1 and which is the #2 Wiz.
« Last Edit: July 18, 2006, 08:01:16 am by MYX »
M    Y    X
Timoe
  • Team-Oh-tAy-Oh
    • Rattlin' Trash
Re: Question for Randy - Wiz49 - USB
« Reply #1 on: July 15, 2006, 11:25:23 am »
He usually writes on the USB port of the encoder "1" or "2", etc.
MYX
    • MYX Digital Blog
« Reply #2 on: July 15, 2006, 02:22:54 pm »
Didn't see it. Where should I look on it?
M    Y    X
kiddk1
  • Last login:August 01, 2022, 10:58:08 am
  • HAP KI DO
« Reply #3 on: July 15, 2006, 03:41:36 pm »
FYI dont mean to hijack this thread but randy I am still waiting on your tech advice regarding my non working keywiz.
Its easy to like someone,
If you dont know them very well.
MYX
    • MYX Digital Blog
« Reply #4 on: July 15, 2006, 03:43:00 pm »
Dude, that was a total hijack. Start a new post or e-mail (pm) him directly.
M    Y    X
mahuti
« Reply #5 on: July 15, 2006, 03:55:21 pm »
C'mon myx, it's obvious that kiddk1 accidentally posted that to this thread.... I mean, he didn't *mean* to hijack the thread, he just accidentally wrote that note, then accidentally hit the post button.
Unlike me, I *meant* to hijack the thread.
Ok, where were we? Oh yeah... trying to find the device number on the board. Where is that printed again?
MYX
    • MYX Digital Blog
« Reply #6 on: July 15, 2006, 04:42:38 pm »
Oh... my bad. (NOT!)
Ghaw. ya big... ya big... jerk.   ;)
Oh yeah, Right... um anyone?
« Last Edit: July 15, 2006, 07:11:40 pm by MYX »
M    Y    X
Timoe
  • Team-Oh-tAy-Oh
    • Rattlin' Trash
« Reply #7 on: July 15, 2006, 05:52:35 pm »
No that dood was a hijaker
I think you can see the number in this pic
Popcorrin
  • Last login:March 06, 2022, 11:11:43 am
« Reply #8 on: July 15, 2006, 06:16:10 pm »
If you plug it in it should tell you under gamepads in the control panel.
MYX
    • MYX Digital Blog
« Reply #9 on: July 15, 2006, 07:11:04 pm »
Steenkin hijackerz
I do not have any numbers like that on my board. Mine basically look identical.
Hey what are you hiding with that big black box?  ;D
« Last Edit: July 15, 2006, 07:12:36 pm by MYX »
M    Y    X
DaveMMR
« Reply #10 on: July 15, 2006, 07:56:22 pm »
I remember reading the device number on-screen when I attached it (probably in the help bubble by the system tray when you attach a new device).
kiddk1
  • HAP KI DO
« Reply #11 on: July 15, 2006, 08:31:05 pm »
been there done that, get over it.  thanks guys
Kremmit
  • - AHOTW -
  • Who the heck is that?
« Reply #12 on: July 15, 2006, 11:26:55 pm »
Randy would not want to pay to produce 4 different pcbs with different ID#s screened onto them, the costs would be conisderably higher.  Using a permanent marker to put the # onto he USB port's metal housing could work, but none of mine have this.
At any rate, it's easy to check- plug one (not both) in, and go to the control panel, look under "gamepads and joysticks" or whatever it is, and the ID# is listed right there.  Now is the time to label it if you want.  Then plug the 2nd one in, and watch it appear in the device manager and note it's ID# as well.
RandyT
  • Last login:August 23, 2026, 02:28:36 pm
    • GroovyGameGear.com
« Reply #13 on: July 17, 2006, 11:10:49 am »
Thanks for fielding that one, Kremmit.
I have been marking the ID numbers on the USB connectors as has been stated.  Evidently, a couple must have gone out without being marked.
However, there is a way to tell.  :)
If you look at the label on the chip, you will see a dot in one of the corners;
Device 1 = No Dot
Device 2 = Green Dot
Device 3 = Orange Dot
Device 4 = Blue Dot
If I can find the space, I'll see about putting a device number checkbox on the next batch of boards.
kiddk1:
If you are the individual that started having problems after removing his trackball for repair, I would look at your wiring.  Chances are high that something in your wiring is shorting.  If that isn't you, my apologies. It's difficult to connect screen names with real ones sometimes.
RandyT
MYX
    • MYX Digital Blog
« Reply #14 on: July 17, 2006, 02:53:09 pm »
I'll check for it tonight. Thanks Randy.
M    Y    X
MYX
    • MYX Digital Blog
« Reply #15 on: July 18, 2006, 08:00:14 am »
Is it possible that you sent me two no dotted pieces? I can not find a dot on these. I plugged them in (one at a time, not both, like Kermit said) and when I look at the control pannel / Game controllers , it shows GPwiz49 status OK but nothing else. I unplug the first and plug in the other and get the exact same thing.
M    Y    X
RandyT
« Reply #16 on: July 18, 2006, 09:46:15 am »
I just pulled up your order.  It seems that you ordered both as device number 1, which would explain the absence of the markings.
If you need to have 1 and 2, then I can swap one of them for you for the costs of shipping.
Let me know,
RandyT
Havok
  • Trade Count: (+17)
Re: I checked but... Still a Question for Randy - Wiz49 - No ID
« Reply #17 on: July 18, 2006, 10:00:35 am »
MYX is a doofus!
 :P
Just kidding!! I almost made a mistake like that once... but then I didn't...
 :angel:
RandyT
« Reply #18 on: July 18, 2006, 11:41:26 am »
Naaahh.  It's a somewhat common error.
I've tried a few different ways to convey how to select the device number, but none of them seem to work very well.  Sometimes I email back with an "are you sure?", but a lot of times people buy more than one of the same device because they are building more than one panel.
RandyT
MYX
    • MYX Digital Blog
« Reply #19 on: July 18, 2006, 12:04:32 pm »
Randy
Is something that is set internal to the chip, or is it something I can solder a jumper to?
How much is the shipping? I have to order some RGB Drives and sumore LEDs. So I will place an order tonight and if it is ok I will add the extra shipping to it.
MYX is a doofus
Well duh!  ;)
Well, Arn't you just special. Wanna cookie?  ;D
« Last Edit: July 18, 2006, 12:07:31 pm by MYX »
M    Y    X
RandyT
« Reply #20 on: July 18, 2006, 12:24:58 pm »
Randy
It's internal.  Send me an email and we can work out the details.  We should be able to do this with minimal expense.
RandyT
Alcathiax
  • Last login:December 16, 2009, 11:32:59 am
« Reply #21 on: July 18, 2006, 12:38:35 pm »
Hey Randy...I would like to order 11-49ways all on device 1  >:D
By the way....just kidding...don't send me an invoice.
MYX
    • MYX Digital Blog
« Reply #22 on: July 18, 2006, 06:55:23 pm »
Arrrgh, but which one do I send him. I can't tell them apart.  :dizzy:
I am just kidding.
M    Y    X
