Author Topic: t-molding fiasco  (Read 3299 times)
soulblazer28
  • Last login:September 27, 2009, 09:12:17 pm
t-molding fiasco
« on: July 13, 2006, 11:51:07 pm »
I think I backed myself into a corner here..
I really had my heart set on the light blue t-molding from t-molding.com, so I designed the overlays and the overall theme with this in mind. Just as I was going to place my order...
Ok well it seems that the light blue t-molding is only available in 3/4" size. My cab is 3/4" MDF alright, but the control panel top was made from 1/2" MDF plus plexi, I need 5/8" molding for that!   I looked high and low and no one else seems to sell the light blue, much less in the 5/8" size.
So what am I to do?  Trimming the excess sounds sloppy.  Good thing I haven't painted anything so I COULD change my color scheme but I'll take that as a last resort.
I doubt anyone was this careless to have gone through this.   :banghead:
NightGod
Re: t-molding fiasco
« Reply #1 on: July 14, 2006, 12:08:14 am »
Get 1/4" Plexi
arcadepcnut
  • Last login:August 15, 2019, 12:03:07 pm
  • Warhammer 40K, you should try it.
    • BREAKTIME
« Reply #2 on: July 14, 2006, 12:08:33 am »
Im kinda in the same boat as you. I build my breatime racing cabinet out of 5/8. I'd like to use xbox green t-molding....but in 5/8 size all I cant find is black white and red. Wish you luck..maybe someone here cant point us to more colors of 5/8.
versapak
  • Somewhere between a block of wood and a monkey
  • Last login:May 17, 2026, 10:28:39 am
  • I am t3h GAY!!!
« Reply #3 on: July 14, 2006, 12:17:57 am »
http://www.t-mold.com carries light blue in 5/8", though they tried some cheap underhanded advertising here once, so I do hate to recommend them.
Q*Bert_OP
  • Oh yes, we did!
« Reply #4 on: July 14, 2006, 12:47:33 am »
I DO NOT recomend buying their t molding. I purchased a 250' roll of ---steaming pile of meadow muffin---.  :banghead: The tmolding from them is slightly smaller than the 3/4" wood, so it tends to look ugly on some cabs. :soapbox:
Instead, make your purchases from www.tmolding.com , as their t moulding is slightly wider, giving a better appearance to your cab, and they will send you some free 6" samples, and mail them for free, so you can decide what you like best  :applaud:
versapak
  • I am t3h GAY!!!
« Reply #5 on: July 14, 2006, 01:23:22 am »
I DO NOT recomend buying their t molding. I purchased a 250' roll of ---Cleveland steamer---.  :banghead: The tmolding from them is slightly smaller than the 3/4" wood, so it tends to look ugly on some cabs. :soapbox:
Yeah...
You need to read the rest of the thread. :P
soulblazer28
« Reply #6 on: July 14, 2006, 02:16:23 am »
Thanks for your suggestion Versapak!  Yes i read about t-mold's disguised attempt at unbias accollade, but if its my last resort then Its something to consider. I guess I'll ask for a sample and compare it with the t-molding.com sample for color, texture, and coverage.
Nightgod, thanks for your reply as well but getting plexi that thick wouldn't fit in with my financial plan.
Q-bert, thanks also for replying but as versa noted, was a bit off track. But I appreciate your feedback on the quality of the tmold and will keep that in mind when i receive the sample.
Thanks again for such a quick response!
edit: ON THE OTHER HAND tmold charges $4 shipping for my free samples. my my my.
« Last Edit: July 14, 2006, 02:18:54 am by soulblazer28 »
gamecreature
  • Last login:October 29, 2008, 08:35:37 pm
  • I'm making this up as I go along.
    • Gamecreature
« Reply #7 on: July 14, 2006, 10:41:22 am »
...and they will send you some free 6" samples, and mail them for free, so you can decide what you like best.
How long does that take? It's been two weeks and I'm still waiting on mine. Can't make an order until I know what color to use and if their fulfillment takes ridiculously long, I may need to go with someone else. :(
Make your cabinet look its best with custom art from
Gamecreature!
« Reply #8 on: July 14, 2006, 01:24:20 pm »
It should've been there by now. They have always been quick to get me my samples.
« Reply #9 on: July 14, 2006, 01:27:26 pm »
Just wondering out loud here -
Would a flush trim router bit trim up overhang t-molding reasonably well?
My CP is 1/2" and all I had was 9/16" white t-mold. I had some overhang on my CP and I was able to cut the slot on my CP 1/16" lower so the overhang was on the bottom portion of my CP. If you have overhang - you might be able to do this as well. See Fig. 1
Fig 1.
NightGod
« Reply #10 on: July 14, 2006, 11:17:13 pm »
Check Ebay, you can get 1/4" plexi insanely cheap over thereI saw this guy, his prices seem really good.
Extreme8
  • Last login:August 24, 2008, 03:46:24 pm
« Reply #11 on: July 16, 2006, 06:39:11 pm »
Try and submit your request for samples again.
The problem seems to be with the form on their website. I had a similar issue but when I submitted a request the second time the samples arrived in a day or two.
These guys are top-notch.
SirPeale
  • Green Mountain Man
« Reply #12 on: July 16, 2006, 09:05:09 pm »
That, or use a brand new razor blade. Slice it right off.
Or use black on the CP instead.
soulblazer28
« Reply #13 on: July 16, 2006, 11:18:09 pm »
If it weren't for Q-bert's remark about the quality of tmold's warez, thats probably what I would have bought.  I sure am not going to pay $5 shipping for a free sample so they lost a sale.
Hmm what if I used TWO slices of 1/8th inch plexi? Think that would work?  I could sandwich my artwork between the two?  Anything I should watch out for such as button length?  Ah the bad part about that is that I already tmold-slotted the CP based on a 5/8th inch girth. *sigh*  If I had only waited!
I suppose I can make a replica of the CP much quicker than the original by just laying it on top of another MDF sheet and using the same holes as guides.
NightGod
« Reply #14 on: July 16, 2006, 11:28:27 pm »
I don't see why sandwiching the art between two sheets wouldn't work for you.
