Author Topic: Updated from Mame32.101 to Mame32b & now some games won't play  (Read 2854 times)
Odin
  • Last login:December 10, 2022, 08:25:21 pm
I upgraded from Mame32.101 to Mame32b.106.  It appears that I have more games in the "Available" folder now, but a lot of them don't work.  When I try to load Star Wars or Tempest or Metal Slug or a variety of other games the screen flashes for a second and it goes back to Mame.  So I went back to Mame32b last verified working version but still no dice on the games that were previously working in Mame32.101..
Is this a setting that I need to change or are these games just not going to work with the newer version of Mame32?
Mame32b says those games are "working" but I can't get them to load up.  Any help is appreciated.
gamecreature
  • Last login:October 29, 2008, 08:35:37 pm
  • I'm making this up as I go along.
    • Gamecreature
Re: Updated from Mame32.101 to Mame32b & now some games won't play
« Reply #1 on: July 08, 2006, 07:47:54 am »
Check your roms. Sometimes a rom changes (or requires the support of a missing bios or parent rom) when Mame is updated.
Make your cabinet look its best with custom art from
Gamecreature!
kiddk1
  • Last login:August 01, 2022, 10:58:08 am
  • HAP KI DO
« Reply #2 on: July 08, 2006, 10:00:03 am »
is there a setting where you specify where the roms dir is in mame32b?
Its easy to like someone,
If you dont know them very well.
Odin
« Reply #3 on: July 08, 2006, 08:03:38 pm »
All the ROMS are recognized by Mame32b but some just stopped playing.  When I load the game the screen flashes black for a second and then it goes back to Mame.  The directory structure is OK because I can see the ROMS from Mame.  Either Mame32b stopped supporting some games that previous versions supported (I don't know why that would be) or I have a setting that needs to be changes somewhere (more likely).  I just don't know where to start looking.
gamecreature
    • Gamecreature
« Reply #4 on: July 08, 2006, 08:21:44 pm »
Sometimes the program will assume the rom is okay when something (such as a bios) is missing. What happens when you validate?
Gamecreature!
Odin
« Reply #5 on: July 08, 2006, 08:54:23 pm »
I'm not sure I understand what you mean by "validate".  I can Audit the ROM and it says it's OK.
unclet
« Reply #6 on: July 08, 2006, 11:29:16 pm »
Can you download command line Mame and see if the game starts correctly?
Did you verify all your v106 ROMS with ClrMamePro?  This will let you know whether the ROMs are correct or not....
BobA
  • What Me Worry?
« Reply #7 on: August 31, 2006, 11:51:31 am »
Ran across the same problem in mame32.106  Noticed MSlug series was not playing.  Would load with no errors but would return to menu without starting game.  Command line mame106 worked fine so roms and BIOS are OK.  Updated to mame32.107 and MSlug works again.  Must have been a bug in mame32.106
krick
  • Gotta have blue hair.
« Reply #8 on: September 02, 2006, 03:09:36 am »
There is no such thing as MAME32b.
There are two downloads available for version 0.106:
mame32s (the s stands for "source", as in source code that must be compiled)
mame32b (the b stands for "binary", meaning a ready to run executable).
The version you have is "MAME32 version 0.106" which is based on the MAME core version 0.106
Hantarex Polo 15KHz
GroovyMAME 0.197.017h_d3d9ex
Windows 7 Home Premium 64-bit
Intel Core i7-4790K @ 4.8GHz
ASUS Z87M-PLUS Motherboard
Pi
  • Last login:March 08, 2007, 03:46:13 am
  • From Jupiter with pride
    • CAESAR
« Reply #9 on: September 02, 2006, 03:30:49 pm »
It sounds as if MAME was trying to change to a graphics mode or refresh rate that your adaptor or monitor don't support. I can't recall the exact options you need to touch, but tell MAME to not change the resolution (so it uses the desktop resolution) and enable hardware stretch.
Pictures in the dark I see - Morpheus comes to me.
