April 30, 2026, 10:18:36 pm
Home
Help
Search
Login
Register
News:
Support this site
Shop
Amazon
through our link. Thank you!
In 2027, BYOAC hits 30 years old.
It started in 1997
. It has cost saint somewhere between $25,000-$30,000 to host in its lifespan.
Main
Main Forum
unable to get ipac to recognize right direction on p2 side
Main
Restorations
Software
Audio/Jukebox/MP3
Everything Else
Buy/Sell/Trade
Project Announcements
Monitor/Video
GroovyMAME
Merit/JVL Touchscreen
Meet Up
Retail Vendors
Driving & Racing
Woodworking
Software Support Forums
Consoles
Project Arcade
Reviews
Automated Projects
Artwork
Frontend Support Forums
Pinball
Forum Discussion
Old Boards
Raspberry Pi & Dev Board
controls.dat
Linux
Miscellaneous Arcade
Wiki Discussion
Old Archives
Lightguns
Arcade1Up
Try the site in https mode
Site News
Unread posts
New Replies
Recent posts
Rules
Chatroom
Wiki
File Repository
RSS
Submit news
« previous
next »
Send this topic
Print
Pages: [
1
Go Down
Author
Topic: unable to get ipac to recognize right direction on p2 side (Read 1148 times)
Kangum
Trade Count:
+1
Full Member
Offline
Last login:February 25, 2018, 07:46:20 am
on:
July 07, 2006, 08:47:53 am »
I am unable to get the player 2 right direction to work on my ipac. I have tried everything from running 2 dedicated wires straight from the controller to hooking up a simple button on the 2 player right direction and it still does not recognize any kind of input.
Also If I fire up the winipac program i can short each terminal to ground and see a simulated button push in the program for every one except from the player 2 right side.
Is my ipac somehow damaged? That is very weird for just 1 input to not work. Any help would be appreciated.
Logged
ArcadEd
Trade Count:
0
Full Member
Offline
Last login:March 04, 2012, 01:25:15 am
Arcade-In-A-Box , Relive Your Childhood
Re: unable to get ipac to recognize right direction on p2 side
Reply #1 on:
July 07, 2006, 02:47:07 pm »
Have you contacted Andy at Ultimarc? That would be my first step.
Also, check the solder side of the board, make sure there is nothing odd around the pin for the 2p right.
Logged
http://www.arcadeinabox.com
miles2912
Trade Count:
0
Full Member
Offline
Last login:October 31, 2019, 05:30:24 pm
My first Home Game. Fairchild System F.
Reply #2 on:
July 07, 2006, 04:28:25 pm »
Try new wires and just use a pushbutton to see if the direction works. Make sure you have a failure by hooking up the pushbutton to another input and seeing if the connect works. Use the winpac software for testing and hope that you are using XP.
D-
Logged
Kangum
Trade Count:
+1
Full Member
Offline
Reply #3 on:
July 07, 2006, 05:09:59 pm »
yes i am using xp. I have tried hooking just a plain button still no go. I also checked behind the board just in case. I have those plastic feet on it so should be good.
I played around with the software for it and everything is recognized except for that 1 input. I also set it to default and hit reprogram. This made the p2 right direction stay lit in the program and cause a repeat keypress over and over. even if nothing is connected to it. This only happens when you try and reprogram it. Its like it wont take that 1 key so it keeps sending it over and over again.
Maybe if something was actually connected to that input on reprogram I could say well maybe the wires are backwards or are connected to the nomally open side. But its happening even with nothing connected to that input as well as no keyboard connected.
i sent a message to andy but im sure he is busy as heck with the holidays and stuff so.
Last Edit: July 07, 2006, 05:18:34 pm by Kangum
Logged
Send this topic
Print
Pages: [
1
Go Up
« previous
next »
Main
Main Forum
