Author Topic: W.G. 33k8111 blows fuse  (Read 1932 times)
candyman
  • Last login:January 20, 2008, 10:36:33 am
« on: July 01, 2006, 02:00:16 pm »
Hi all,
 I got a golden tee '98 with a W.G. 33k8111 in it. As soon as power is applied, it blows fuse F100.  If I disconnect the power supply board (from main pcb) and apply power, the fuse will NOT blow. So I belive the problem is on the main pcb. The unit has not been capped yet, but I would like to know if there maybe a more likely problem area. I have tried emailing Wells Gardner for tech help and manual, but they have not replied.
  Thanks for any help and have a SWEET DAY!
Kevin Mullins
    • Me on Myspace
Re: W.G. 33k8111 blows fuse
« Reply #1 on: July 01, 2006, 03:46:43 pm »
I'm assuming that the F100 fuse is on the monitor chassis, or is this a cabinet fuse?
And are you talking about the game pcb when you say "main pcb"?
Just trying to get a better idea of the problem here.......
(never seen a game pcb blow a monitor chassis fuse)
candyman
« Reply #2 on: July 01, 2006, 04:59:02 pm »
Kevin,
  This model has 3 pcbs the first is a power supply mounted to the side of the chassis. It converts 120ac to 24v dc and B+(124?)dc.. This than supplies the main pcb that lies under the tube as in most models, and than there is the standard neck pcb. I removed all pcbs and checked for the usual burn marks, bad solder connections, dead animals, ect.. Everything "looks" ok, but I have never delt with this model and only have a bad copy of the elec. schem.
Thanks for your help.
grantspain
  • Online Online
  • Last login:Today at 02:39:47 am
« Reply #3 on: July 01, 2006, 05:22:13 pm »
i would be looking towards the psu board,maybe on the primary ac input(degauss coil and ptc componant,diode or bridge rectifier-anything the ac input really)
« Last Edit: July 01, 2006, 05:48:30 pm by grantspain »
candyman
« Reply #4 on: July 08, 2006, 12:52:38 pm »
Hi all,
  I have checked out the power supply board and all seems fine. I did find the Horz. output trans. is bad, I ordered a new one along with a cap kit. I will let everyone know after I get them installed.
grantspain
  • Online Online
« Reply #5 on: July 08, 2006, 01:47:15 pm »
sounds very likely you have found the fault-the h.o.t,good idea to change the caps as well,hope it goes well
