Author Topic: Can I use a different chassis for my monitor?  (Read 1789 times)
markymarky99
  • Last login:August 20, 2017, 01:53:05 pm
« on: June 29, 2006, 06:11:06 am »
I have a  VISION PRO monitor which now has a bad chassis.  I have a brand new chassis that was pulled from what I believe was a Pentranic monitor that had a bad tube.  The connections look exactly the same .  It seems as if you could simply plug this PEN chassis right in to the monitor of the VISION PRO.  Would this work?  thanks for your time, mvc
grantspain
  • Last login:Yesterday at 05:23:04 pm
Re: Can I use a different chassis for my monitor?
« Reply #1 on: June 29, 2006, 06:21:54 am »
that all depends on whether they are both the same resolution tubes,the same yoke impedence, and tube neck pins are the same-i have looked at your related posts and i believe you have only blown that component on the heat sink,worth changing that first
Ken Layton
  • Guru
  • Technician
« Reply #2 on: June 29, 2006, 10:52:32 am »
See this site for chassis/tube swaps:
www.8liners.com/datatech/monitor.html
