Author Topic: GAMEEx: Setting up KEGA and setting as shell (Possible?)  (Read 1415 times)
RTSDaddy2
  • Last login:April 03, 2014, 08:28:03 pm
  • Bees! Oh bother!
« on: June 25, 2006, 01:14:31 pm »
Anyone out there using GameEx who knows how to set it up correctly to make KEGA run, I could use your help.
Also, with WindowsXP, is there any way to make GameEx run on startup (appear as the shell, I suppose is the correct term)?  Just curious!
Thanks ahead of time! :notworthy:
RTSDaddy2
  • Bees! Oh bother!
Re: GAMEEx: Setting up KEGA and setting as shell (Possible?)
« Reply #1 on: June 26, 2006, 04:40:27 pm »
Well, to some degree I've gotten Fusion up and working with GameEx...it at least starts the emulator, then you choose the rom.  I'm sure it's a command path problem, but don't know what I need.
As far as doing the shell thing, I just saw exiges' wonderful explanation of the same a few posts below this and it looks brilliant and well thought out.  I'll just go follow it.  Thanks guys!
This is the title of exiges excellent article=> Summary: Hiding XP / Booting to your Emulator / Optimizing boot
« Last Edit: June 26, 2006, 04:42:48 pm by RTSDaddy2 »
