Author Topic: Mini ITX to TV? (TV-out)  (Read 3474 times)
Otraotaku
  • Last login:May 17, 2025, 05:38:18 am
  • トラビス
« on: June 23, 2006, 11:47:05 pm »
i recently got an ITX board im going to use in a project but i cant seem to find out how to hook it up to a TV. it says its TV-out capable right out of the box yet i cant seem to find the cables or what ports to use in order to acomplish
i also look on my board and see n S-video or RCA ports?  :P
« Last Edit: June 24, 2006, 08:45:00 pm by Otraotaku »
Otraotaku
  • トラビス
Re: Mini ITX to TV? (TV-out)
« Reply #1 on: June 24, 2006, 02:25:07 am »
if theres nothing i can do with what i currently have on the mobo, whats the best/easiest way i can get it up and running on my TV? also if possible i did find a small enough video card that has S-video. isnt there any VGA to TV? anyways, any other options?
grantspain
  • Last login:September 29, 2026, 03:33:53 pm
« Reply #2 on: June 24, 2006, 03:51:29 am »
according to their tech download your motherboard has two tv outputs right next to the vga plug(i would use the rca phono)so if your board has not got them then its not an original board or perhaps its a completly different model.
Otraotaku
  • トラビス
« Reply #3 on: June 24, 2006, 05:39:39 pm »
yeah it has neither. and the smallest PCI card i can find only has S-video
Kevin Mullins
    • Me on Myspace
« Reply #4 on: June 24, 2006, 06:13:37 pm »
You can get an S-video to RCA composite adapter at Radio Shack and maybe even Walmart.
Just video only of course.
And the picture quality will be composite.
Kevin Mullins
    • Me on Myspace
« Reply #5 on: June 24, 2006, 06:47:13 pm »
Double check on your board itself what Model it is.... should say something like EPIA -V right on it...... the actual "series" of mini-ITX board.
Just to make sure we're looking at the right info for ya also.
I found a manual for the V series, but your e-mail address wasn't working.
It clearly shows the video ports.
« Last Edit: June 24, 2006, 06:51:53 pm by Kevin Mullins »
Otraotaku
  • トラビス
« Reply #6 on: June 24, 2006, 08:26:27 pm »
it says epia-V10000a on the LTP or whatever ya call the Printer port, thanks for going through all the trouble though, i just really need a quick and easy solution for TV-out...
[EDIT/ADD]
i also have a bunch of cords/cables for composite video etc /S-video that  even came with my card and stuff. when i tried hooking it to my Video card on my desktop it never worked. you think you could explain all that i would need? ive been trying to use it on a S-Video out to S-video on a RF-Switch to my TV. and even tried using an S-video to RCA on my gamecubes LCD.
« Last Edit: June 24, 2006, 08:43:14 pm by Otraotaku »
Kevin Mullins
    • Me on Myspace
« Reply #7 on: June 24, 2006, 08:37:44 pm »
Is there anything else labeled directly on the green pcb itself?
Where did you get your specs from?
Because that doesn't look the same as the V series I was looking at.
Like you said.... I don't see any video port either.
Should have been right next to the printer port if it were a V series.
You may have to go with the pci video card option.
Otraotaku
  • トラビス
« Reply #8 on: June 24, 2006, 08:44:34 pm »
lemme grab the link, all the info was provided in an ebay auction. (sad thing is i havent even powered it on yet to see  whats onboard...   :-\
here it is... http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=6889527072&rd=1&sspagename=STRK%3AMEWN%3AIT&rd=1
« Last Edit: June 24, 2006, 08:46:09 pm by Otraotaku »
Kevin Mullins
    • Me on Myspace
« Reply #9 on: June 24, 2006, 08:49:05 pm »
Well......I take that back..... after comparing the V manual and your pic......it does look like yours has the TV out chip and everything else in the right location.
Is that the right I/O shield?
Maybe the ports are just hiding behind it. ???
I can send ya the manual I'm looking at if you don't already have it.
But need to make absolutely sure it's the right one.
Otraotaku
  • トラビス
« Reply #10 on: June 24, 2006, 08:58:07 pm »
im telling ya, there not there. i noticed a few unsoldered spots under the printer port but thats it. also the empty holes on the back of the metal plate (I/O shield) . id like to see that manual seeing as i didnt get one in the mobo box.
i think its just not completed...
« Last Edit: June 24, 2006, 09:02:44 pm by Otraotaku »
Otraotaku
  • トラビス
« Reply #11 on: June 24, 2006, 09:07:03 pm »
ah... this is driving me nutz, id like to slice the man's hand off, who didnt finish soldering my board with the I/O shield  :angry:
Kevin Mullins
    • Me on Myspace
« Reply #12 on: June 24, 2006, 09:09:35 pm »
This is the V8000.....
http://www.via.com.tw/download/mainboards/4/8/epia-v-h2.jpg
You can clearly see the RCA connection next to the printer port.
Yours should be exactly like it.
Sounds like somebody swiped it.
(not there)
Otraotaku
  • トラビス
« Reply #13 on: June 24, 2006, 09:13:04 pm »
does the v10000 look exactly like the v8000? that pic you just showed is exact w/o the v10000 labels
Kevin Mullins
    • Me on Myspace
« Reply #14 on: June 24, 2006, 09:15:10 pm »
That last pic you had is Exactly where it should be...... BUT IT'S NOT THERE.
hmmmmmm..... gonna have to get one or rig one...... but that's where it should be.
I assume they are the same, all the boards in that series looked identical.
You are just flat out missing it.
Does it look like someone removed it?
Or are the solder spots pretty flat and just never been used?
Otraotaku
  • トラビス
« Reply #15 on: June 24, 2006, 09:16:40 pm »
they seem pretty flat (especially under the board)
nah, only a few are... some are bumpy with tiny bubbles... but it doesnt look like someone soldered still
Kevin Mullins
    • Me on Myspace
« Reply #16 on: June 24, 2006, 09:17:46 pm »
Radio Shack may even have some "surface mount" type connectors for that.
(of course they get worse and worse with time)(Radio Shack)
Or have to rob one from something else.
Flat solder - probably was never there.
Otraotaku
  • トラビス
« Reply #17 on: June 24, 2006, 09:21:20 pm »
i probly couldnt solder a working connector on there any way. would it really be easier with RCA? over S-video? i really need to be able hook this thing to pretty much any TV. just as you would a video game console. thats what im aiming for.
Otraotaku
  • トラビス
« Reply #18 on: June 24, 2006, 09:27:48 pm »
also i dont know if you noticed this. but theres only one IDE type connector, does that mean you have to put a CD drive onto the Slave? and harddrive on the main or no CD drive at all?
Kevin Mullins
    • Me on Myspace
« Reply #19 on: June 24, 2006, 11:36:39 pm »
If you have any soldering capability it should be easy if you find the right one for it.
Or take it down to a PCshopand explain to themwhat you need, they might be able to hook you up with something.
If you expect to be ableto hook up to "any" TV then you would probably want the RCA.
But you could use that S-video pci card as S- video is very common now, and just also get one of those adapters to have on hand for RCA.
You can slave the CD drive. Get an IDE ribbon cable with the extra connector in the middle. My PC is setup like that.
Go from PC to Harddrive to CD drive on the end.
Master the harddrive.
I'm not the PC guru on that one, but I know it can be done.
Send me your e-mail and I can send this manual to ya.
The one on your profile didn't work for me.
Otraotaku
  • トラビス
« Reply #20 on: June 25, 2006, 12:12:39 am »
Thanks for all the info, all i need now is some ram and a PSU and i should be okay. thanks again
