Author Topic: Rockola 440 Oppurtunity  (Read 3818 times)
USSEnterprise
  • Last login:October 11, 2007, 11:15:08 pm
    • USS Odyssey
« on: June 20, 2006, 03:51:58 pm »
I have a chance to get a Rockola 440 really cheap. Only problem is the record arm is stuck in one position. The amplifier and coin mechs work. Does this sound like an easy fix?
Proper capitalization is the difference between helping your Uncle Jack off a horse, and helping your uncle jack off a horse.
Ken Layton
  • Guru
  • Technician
Re: Rockola 440 Oppurtunity
« Reply #1 on: June 21, 2006, 12:08:34 am »
Might be a mechanical problem due to dried out grease or someone trying to "fix" the machine who shouldn't have tried in the first place.
Could be a bad motor (usually the motor windings short to frame ground) which are expensive to replace.
Could be dirty relay contacts.
Could be blown fuse/ circuit breaker.
Could be dirty slip rings.
Could be bad power supply.
Could be any of a million things.
USSEnterprise
    • USS Odyssey
« Reply #2 on: June 21, 2006, 12:30:23 am »
I asked him as to how the arm broke. Says he was adding records with the thing on, and his shirt got caught up in the arm mechanism. What a genius
Barry Barcrest
  • Simple Plan
    • E-Touch Jukebox
« Reply #3 on: June 22, 2006, 04:08:36 am »
What a genius
Hmmmm think about this statement before you make any purchases.
USSEnterprise
    • USS Odyssey
« Reply #4 on: July 05, 2006, 09:33:38 pm »
I'm trying to figure out whether or not to get it. its $215 and a not too far drive
USSEnterprise
    • USS Odyssey
« Reply #5 on: July 16, 2006, 04:40:33 pm »
I think I'm gonna go for it.
