Author Topic: Zinc Controller set up...GameEx [config set up included]  (Read 2819 times)
Syxx
  • Last login:June 25, 2006, 06:36:25 pm
  • Bling Bling
« on: June 19, 2006, 05:07:20 pm »
Im trying to get Zinc to run with GameEx all is working now except I cannot get it to point to my controller config...
Im using winterblasts input addon and I used ZincFE to set up the controller buttons...once set I then made...
ZINC.CFG to add in GameEx Config so that It will launch all options with --use-config-file=zinc.cfg
With in Zinc.cfg I have....
;default setup
--sound-filter-enable=yes
--renderer=c:\zinc\d3d_renderer.znc
--controller=c:\zinc\pcfg\controller.znc
--use-controller-cfg-file=c:\zinc\pcfg\controller.cfg
nothing will work it just hangs then goes back to GameEx...if I run command line or with ZINCFe it works fine...
If I remove the line --use-controller-cfg-file=c:\zinc\pcfg\controller.cfg it loads but does not have my buttons set up....really frustrating does anyone know what I could be doing wrong?
Its not lack of trying either have spent almost 3 hours trying to figure this out and about 2-3 yesterday also...some assistance would be greatly appreciated.
 :banghead:
