Author Topic: Game lists in Mala (and others)  (Read 8737 times)
Johnny
  • Last login:March 11, 2026, 09:49:03 pm
  • I Want My Own Coctail Cabinet!!
« on: June 18, 2006, 12:00:47 am »
Is there any easy way to remove the extra info in the game lists?
The gamelist look like this in Mala and other Front ends:
Pacman (midway)
Pengo (Set 1 Rev c)
Phoenix (Amstar)
etc
I want it to look like this:
Pacman
Pengo
Phoenix
etc
If not, I have to use GameLauncher, but I would prefer to use a frontend that is updated.
« Last Edit: June 18, 2006, 12:14:57 am by Johnny »
Johnny Andersen
 Oslo - Norway
Johnny
Re: Game lists in Mala (and others)
« Reply #1 on: June 18, 2006, 12:14:16 am »
Never mind guys, I'll found it!
(I can't read...... :banghead:)
Johnny Andersen
 Oslo - Norway
« Reply #2 on: June 18, 2006, 12:15:55 am »
Yes. I've seen this question asked a few times. You can use this:
http://mala.arcadezentrum.com/malagamelist.html
Or simply launch the MalaGamelist editor inside the mala folder. Make your changes and save. Done!
CyrusMzRG
  • Last login:July 14, 2019, 07:01:50 pm
« Reply #3 on: June 18, 2006, 05:08:15 pm »
Hi, I am trying top  rename all my mame roms erasing the brackets and allways my computers hungs and few minutes later into  the gamelist program an error apperas whichs says:
"zu wenig arbeitsspeicher"
what can I do?
thank you
swindus
  • Last login:July 28, 2021, 05:52:50 am
    • MaLa - M.A.M.E. Launcher
« Reply #4 on: June 19, 2006, 05:44:34 am »
"zu wenig arbeitsspeicher" means not enough memory, but I don't think that this is the real issue here.
What are your computer specs?
CyrusMzRG
« Reply #5 on: June 19, 2006, 07:57:58 am »
Hello, I have tried in 2 PC, and  both are similar, P IV 2.8 GHz 1Gb RAM
swindus
« Reply #6 on: June 19, 2006, 08:21:58 am »
Strange, I have tried more than 5 PC's and it never hangs and I know a lot of people using MalaGamelist without errors. Maybe someone else can confirm this.
CyrusMzRG
« Reply #7 on: June 19, 2006, 09:15:21 am »
If I select no more than 50 roms it works ok, but as you know mame has more than 6000 roms, and it is very boring rename the roms step by step, I hope as you say, anybody can help me
Cyrus
« Last Edit: June 19, 2006, 09:59:43 am by CyrusMzRG »
swindus
« Reply #8 on: June 19, 2006, 09:48:33 am »
You are right! I did a test with a huge game list (> 6000) and the error appears here too. I already found the bug and it is fixed. Now it takes only 1 second to remove the brackets from the names in huge lists. Thanks.
« Last Edit: June 19, 2006, 10:02:19 am by swindus »
CyrusMzRG
« Reply #9 on: June 19, 2006, 10:01:18 am »
That's great, thank a lot for your help, and waiting for the version with that bug fixed, thank you, now I
