Author Topic: Suzo trackball question  (Read 3634 times)
Cameronj
  • Last login:August 03, 2012, 12:59:01 pm
  • I'm a Super llama!
« on: June 17, 2006, 02:10:24 pm »
I have a Suzo Trackball that I bought from Ultimarc. I am in the process of installing it and am having some space issues.
Do I really need those plastic covers that go over the encoders? They are really getting in the way. Do they make a difference to the performance of the optical sensors?
Level42
Re: Suzo trackball question
« Reply #1 on: June 17, 2006, 02:35:49 pm »
I've got the same trackball, however not in use yet. I think the covers are for protecting from any light coming in, so if your cp is closed it should be OK. Or maybe they should prevent dust ? I'd say give it a try withouth them.
Cameronj
« Reply #2 on: June 18, 2006, 02:40:16 pm »
My CP might have a bit of light going on with all of the LEDs running. I guess I will have to see how it performs. At this point, I can't fit the covers. If necessary, I will make new ones  I guess. Thanks for the response!
RandyT
  • Last login:June 24, 2026, 02:15:54 pm
    • GroovyGameGear.com
« Reply #3 on: June 18, 2006, 10:07:38 pm »
The covers are more likely for dust control puposes than light.  Unless you have an IR source under your control panel, you shouldn't need to worry.  Normal light shouldn't affect the sensors.
RandyT
« Last Edit: June 19, 2006, 09:41:56 am by RandyT »
Cameronj
« Reply #4 on: June 18, 2006, 11:30:56 pm »
OK Thanks RandyT! I won't worry about it then. No IR sources under there (Yet).
