Author Topic: happs trackball only goes up and down  (Read 1426 times)
kiddk1
  • Last login:August 01, 2022, 10:58:08 am
  • HAP KI DO
« on: June 17, 2006, 12:04:57 pm »
I installed my happs trackball about a week ago and it was working fine, now it seems to only go up and down and will not go left and right, this is also my mouse so I need to to go every direction.  anyone know why this is happening?  thank you.
Its easy to like someone,
If you dont know them very well.
DaveMMR
Re: happs trackball only goes up and down
« Reply #1 on: June 17, 2006, 07:00:58 pm »
Did you check to see if the wires are all connected?
kiddk1
  • HAP KI DO
« Reply #2 on: June 17, 2006, 10:37:40 pm »
yes, they are connected via optiwiz cable and pcb interface, for some reason it is now working it is intermittent.
DaveMMR
« Reply #3 on: June 17, 2006, 11:25:11 pm »
Check to see if the wires are connected loosely.  It could be possible that the connector is barely making contact leading to those intermintent problems.  Re-connect the X-Axis wires just to be doubly sure.
By the way, if you already did this, sorry for being repetative.
