Author Topic: Coin Mech Help!!  (Read 2061 times)
gwood1234
  • Last login:November 22, 2022, 12:29:56 pm
Coin Mech Help!!
« on: June 15, 2006, 11:40:42 am »
Hi,
I have just acquired a coin mech and credit board for my MAME project. When I try to connect it up the I-PAC I seem to get a continuous credit signal, in other words, the credits are flooding into the game without even inserting a coin!
Just wondered if you knew what the problem could be?  I bought it in working order from a reputable guy on ebay..  It's a Sentinel coin mech but not sure what make the credit board is..
Any advice is much appreciated!
Kind regards
Gareth
Shape D.
  • Last login:July 05, 2012, 06:17:57 pm
  • >Look at me, I'm a Newbie<
Re: Coin Mech Help!!
« Reply #1 on: June 15, 2006, 07:42:13 pm »
Id check to make sure your ground and hot wire aren't touching. Also theres a little lever on the side of the coin mech that moves down when a coin is inserted. Make sure thats not stuck down. If you need to check put a quarter in while watching the side of it, if nothing moves than youre thingy is stuck down.
Hey Baby, Have you ever met a Newbie with 38 pages of previous posts before? Do you Want to?
deadkenndys1105
  • Last login:November 27, 2012, 03:55:05 pm
« Reply #2 on: June 15, 2006, 09:27:45 pm »
Are you sure you wired it to the opening prong and not the closed one.
17 years old and totaly addicted.
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #3 on: June 16, 2006, 12:25:00 pm »
Sounds to me like he got some ELECTRONIC coin mechs, not your standard ones.
GWOOD, you may have to give us more info (model #, pics?) and maybe a reason why you opted for electronic over the simple mechanical variety.
The IPAC is designed to receive coin input as a simple "button" switch closing. Each time it closes, that's one credit detected by whatever game MAME is running. There is no need for a "credit board", unless by credit board we are talking about an optical coin switch?
Either way, check as was suggested above, that your connection must be set up in a "normally open" way, not "normally closed".
NO MORE!!
