Author Topic: Black light?  (Read 2981 times)
Gaston77
  • Last login:February 21, 2011, 06:53:44 am
  • MDF nearly killed me!
Black light?
« on: June 14, 2006, 09:32:21 am »
I am looking for a black light tube no longer than 60 cm to fit in my cab ( for the backlight on the marquee). Problem is, I can only find the bulbs. Which get too hot in the cab.
anybody know of any manufacturers in Europe which produce these units and who possibly also sell online?
this is my........BOOMstick!
trcroyle
  • Last login:December 05, 2007, 10:32:05 am
Re: Black light?
« Reply #1 on: June 14, 2006, 11:08:36 am »
Here's the first one from a google search of "black light" fluorescent UK:
http://www.lightbulbs-direct.com/browse_category.asp?Mode=prods&PGID=60
Any of the T5s and the first 2 of the T8s fit your specs.
maxlamer
  • Last login:June 20, 2006, 09:45:12 am
  • I like stuff
Re: Black light?
« Reply #2 on: June 15, 2006, 12:34:34 am »
dont blacklights fit into a regular fluro fitting  ???
vrf
  • Last login:October 13, 2017, 10:11:54 pm
    • Pixelbox
Re: Black light?
« Reply #3 on: June 15, 2006, 04:44:43 am »
Yeah, I think it's just the bulb that's different. Just a regular flourescent light fixture.
By the way, why the black light for a marquee light? Won't the marquee block the effect?
lloydcom
Re: Black light?
« Reply #4 on: June 15, 2006, 04:53:27 am »
Hi,
I use cold cathode lighting in my cab for the marquee and it works a treat.  Also if you are in the UK, Maplins have these on sale for a
« Last Edit: June 15, 2006, 04:55:15 am by lloydcom »
vrf
    • Pixelbox
Re: Black light?
« Reply #5 on: June 15, 2006, 05:01:02 am »
yeah, cold cathode tubes are awesome. I'm using a couple of the 4" white kind in my micro cab. Molex-powered for easy on/off!
deadkenndys1105
  • Last login:November 27, 2012, 03:55:05 pm
Re: Black light?
« Reply #6 on: June 15, 2006, 04:37:47 pm »
Dont use a black like the look horable as a backlight in most cases.  I use one and im switching it out for a normal light.
17 years old and totaly addicted.
Gaston77
Re: Black light?
« Reply #7 on: June 16, 2006, 05:15:45 am »
Ok, you convinced me. I will not use the blacklight  for my cab. I will check Maplins out. There must be an equivalent somewhere around here....
Thanks you guys.
Dean
  • Last login:September 30, 2006, 07:38:27 am
Re: Black light?
« Reply #8 on: June 16, 2006, 10:49:58 am »
Hi,
lloydcom
Re: Black light?
« Reply #9 on: June 16, 2006, 04:04:33 pm »
rugby1
  • Last login:April 12, 2007, 12:10:12 am
Re: Black light?
« Reply #10 on: June 16, 2006, 05:14:37 pm »
Cold Cathodes here:  http://www.xoxide.com/coldcathodes.html
Pretty cheap ($7.99) for the dual kits.
Dean
SOAPboy
  • Last login:August 01, 2009, 03:36:12 am
  • ..::GeeK::..
