Author Topic: capacitor question??  (Read 3546 times)
kjoel0123
  • Last login:January 07, 2012, 09:57:19 am
  • Cabs for sale - Please see my flickr page for all
« on: June 13, 2006, 11:10:32 pm »
What is the purpose of the capacitor in an arcade?
capacitor specs:
25vdc , 18000mfd, it sits between the transformer and the power board, Game is outrun,
Can i eliminate this and just wire 12v to my new power supply?
Testing 15v with meter
thanks
Dedicated Cabaret cabs I currently own:
Neo Geo/ GT Complete/Mspac galaga reunion
full size cabs: Playchoice 10 Single Monitor/Nicktoons Racing/Junior King Cocktail/ Super Punchout/
Pins- Revenge From Mars/ Black Rose/ LW3
For Sale/ Trade: Digdug in Ireland Cab/83' Chexx Hockey/Battlezone/PC10 Bartop with 6 games
Check out http://www.flickr.com/kjarcade <--not updated
SirPeale
  • Green Mountain Man
Re: capacitor question??
« Reply #1 on: June 14, 2006, 01:34:45 am »
I have an Outrun that has been converted to use a switching power supply.
I did not do the conversion myself, so I don't know what's entailed.
D_Zoot
  • Last login:November 18, 2010, 03:59:37 pm
  • Sorry if I get any spit on you...
« Reply #2 on: June 14, 2006, 10:31:36 am »
I don't have an outrun handy myself, but:
That cap might sit in the cab between the transformer and power supply, but it would be wired into the supply somewhere, likely between the rectifier and regulation circuits.   It's a filter cap to smooth the power after rectification.
If you are installing a switching power supply, you won't need it.
D
kjoel0123
« Reply #3 on: June 14, 2006, 11:29:42 am »
It does sit between the transformer and the small power board, wired from transformer to cap to power board, I will eliminate the cap and the transformer , but still need a working pcb..
Peale is there a capacitor in your cabinet with the new supply? Please verify, thanks
Level42
« Reply #4 on: June 14, 2006, 01:53:53 pm »
On old (conventional) power supplies, a cap like that is used to smooth out (filter) any left overs from the AC. However, a modern switching power supply is already filtered for any AC components within the power supply itself. So there should be no need for the cap anymore. Those really big one's are pretty expensive as well...
Check if the currents that the switching supply can deliver is at least as much as the old supply could.
kjoel0123
« Reply #5 on: June 14, 2006, 02:29:42 pm »
The new supply can handle the current  from the older one, all that the older supply has was 2- 5v connectors , 2- ground connectors and 2 lines for the ac. Thanks for the info, once I get home I am yanking out the old cap and transformer and rewiring the wires from them. So far the wiring is about 70% completed. Just still need an outrun pcb that works so that I can play the damn game, If you know of anyone, please drop me a line, thanks again.
SirPeale
« Reply #6 on: June 14, 2006, 06:53:06 pm »
Nope!
kjoel0123
« Reply #7 on: June 14, 2006, 10:44:17 pm »
Just removed the transformer wiring and the capacitor. I removed the pcb and the battery tests 4.2v. should be 5.5v.
Will this cause my video to scramble all the colors?
Will changing the battery on this board kill the pcb?
My cab has 2 boards -My board numbers:
cpu board- 171-5376-01
other #'s found on the cpu board
837-6-63-02 rev b
834-6065-04 rev b
171-5377-01- 2nd board
Anyone know these answers please let me know, thanks
« Last Edit: June 14, 2006, 11:08:01 pm by kjoel0123 »
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #8 on: June 15, 2006, 02:00:58 am »
I assume you tried adjusting the +5v via the power supply's knob...
NO MORE!!
SirPeale
« Reply #9 on: June 15, 2006, 07:58:24 am »
Are all power supplies adjustable?
Kevin Mullins
    • Me on Myspace
« Reply #10 on: June 15, 2006, 10:15:06 am »
You might want to investigate that question here:
http://www.arcadecollecting.com/dead/dead.html
Looks like Outrun is on the list......
(along with many other games I never realized did)
