Author Topic: Connct PS/2-IPAC to USB?  (Read 1898 times)
Luigi
  • Collecting/restoring cabs
« on: June 13, 2006, 07:50:47 am »
Hi.
I'm using an I-Pac in my Mame-Cab connected to the PS/2-Port. Works very well.
Does anyone know if there is a differende between the USB-Version and the PS/2-Version?
A guy in a german forum wrote that the only difference is, that a cable with an USB-connector is deliviered.
Can I simply use an USB-2-PS/2-Adaptor to use the I-Pac at the USB-Port?????
hanelyp
  • Last login:January 10, 2009, 11:08:19 pm
Re: Connct PS/2-IPAC to USB?
« Reply #1 on: June 13, 2006, 11:06:47 am »
A keyboard encoder through a generic PS/2 to USB adaptor should work fine as long as a limit of left/right(<shift><ctrl><alt><'windows'>) + 6 other keys pressed at once is enough.  Given that you usually want to avoid the 'windows' key for joysticks and triggers, that gives from 6 to maybe 12 usable keys at once.
Luigi
« Reply #2 on: June 13, 2006, 01:57:41 pm »
Thanks.
The number of pressed keys doesn't matter (only calssic games are played with max. 2 buttons). Connecting to my Notebook is the problem since it doesn't have a PS/2-Port ;)
So I'll give it a try :)
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
« Reply #3 on: June 14, 2006, 11:17:50 am »
The I-PAC is a dual-interface device and fully supports USB. To use one which was shipped as a PS/2 in USB mode you need either the cable we supply or the type of simple "plug type" of adaptor which is often supplied with dual-interface keyboards or mice.
Don't use a PS/2 to USB converter! As well as running into the 6-key limit you will find another more serious problem which is that these converters "cancel" any held-down keys after a couple of seconds to avoid stuck keys in USB (which causes a key repeat situation). This is of course hopeless for gaming.
Andy
Luigi
« Reply #4 on: June 19, 2006, 04:58:43 am »
Hi Andy.
I just did a test on saturday....and after I thought about changing the jumper from PS/2 to USB  ::) it worked very well. I used a simple PS/2-USB adaptor from an USB-mouse.
Now I need a new I-Pac for my Mame-Cab...will the I-Pac VE be available soon??
