Author Topic: Hacking arcade Speakers to pc speaker  (Read 4690 times)
aricade
  • Last login:August 15, 2004, 01:38:26 pm
  • Wamma langa ding dong!
    • Isaacade
« on: March 06, 2003, 08:56:45 am »
Hi guys,
First post and am a newbian. be gentle with me ;)
I have an arcade cabinet wich I purchased from my local arcade.  It came with 2 speaker mounted underneath the marquee area.
I found infor on hacking cheap pc speakers from this site.
So I had an old pair of speakers wich I took apart.  soldered the wires back together again and it still works! ;D
So I was wondering  Are the speakers that came with my arcade cabinet compatible with the pc speakers? (ie can I replace the dinky speakers with my arcade speakers?)
Is their any advice you guys could offer me on testing and hooking up these arcade speaker to my computer.
Just thought I should check with you guys and do it right the first time!
TIA
Aricade
Off all the things I've lost I miss my mind the most!!
Birdtales
  • Last login:October 06, 2020, 10:00:31 am
  • You won't like me when I'm angry.
    • Birdtales
Re:Hacking arcade Speakers to pc speaker
« Reply #1 on: March 06, 2003, 12:21:33 pm »
I did it. I just took the little PC speakers out of the circuit, ran longer wire and hooked it up to the existing arcade speakers. Then I hot glued the volume pot/board inside my CP so I could get to it.
Coming Soon
gnateye
  • Last login:December 05, 2011, 11:22:36 am
  • 4 cabs and counting!!!
    • natty's arcade
« Reply #2 on: March 06, 2003, 01:27:19 pm »
io was able to use my existing speakers in my millipede cab, they are basically nice car speakers, my computer speakers i got from ebay for 40$ are 2 satelite speakers and  a nice subwoofer, the sub has wire inputs on the back where you would twist the speake rwire and insert it into the hole for a connection, i just tested the existing (mono) wiring by plugging it into the back ofg the sub, worked great so after looking at the cab speakers and realizing that they are just using the same .187 female quick connects to connect thge speakers, i undid them and made up 2 sets so now my cab is stereo and it BOOMS! the sub can really generate some bass, and games sound awesome!
just lok around for a nice set of speakers that you can use and make sure they are 2watts 8) you should be fine!
aricade
    • Isaacade
« Reply #3 on: March 07, 2003, 08:30:16 am »
 :D
Thanx for the info guys.
I tried it and it worked! 8)
Speakers in my a cabinet have a better sound quality!
I think this is going to work nicely!
Thanx
Aricade
