Author Topic: Using a resistor to provide load on the power supply. *updated*  (Read 2224 times)
kagem
  • Last login:June 09, 2006, 11:32:17 am
Ok, got a jpac and since there's no jamma board hooked up to the power supply, I figured I would use resistors to provide load.  I was just wondering if using two 1.0 ohm 10W 10% Wirewound Resistors wired in series would work?  I was then planning to use a case fan on the 12v+ rail to help cool down the resistors.
I'm trying to use these resistors since I can easily get them at radio shack.  If they have better ones that I can easily get, then please let me know.  Thanks.
**Update**
I went ahead and tried it out and it seems to work just fine.  I had it on for about 30 minutes and the power supply didn't blow up or turn off so I guess  it's ok  ;D
Tips if you want to do this:
Make sure you wire the 2 resistors in series and not parallel.  Also they do get hot so keep them seperated and away from anything that can get damaged.  I attached them on top of an old cpu heatsink with cable ties and wired a 12v case fan pointed at them.  I'm not sure if this actually helps or not but I don't see how it can hurt.
The resistors come in a two pack from Radio Shack at $1.79  Catalog #: 271-131
« Last Edit: June 09, 2006, 11:27:32 am by kagem »
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
Re: Using a resistor to provide load on the power supply.
« Reply #1 on: June 07, 2006, 11:21:36 am »
It would make more sense to just disconnect the AC from powering your power supply.
Or if you want to be neat about it, add in a second AC toggle switch.
NO MORE!!
kagem
« Reply #2 on: June 07, 2006, 11:25:41 am »
Yeah, I'm still debating which way to go, but main reason I want to keep the powersupply hooked up is because my monitor gets power from it, and this way I can easily pop in a jamma board if I wanted to.
RayB
  • There's my post
    • RayB.com
« Reply #3 on: June 08, 2006, 09:18:04 am »
Wait, are we talking about a power supply or the AC distribution block? I've never heard of a monitor that can run off DC voltage (unless you've got one of those mini LCD screens...?)
NO MORE!!
RayB
  • There's my post
    • RayB.com
« Reply #4 on: June 08, 2006, 09:19:56 am »
reference:
NO MORE!!
StephenH
« Reply #5 on: June 09, 2006, 02:52:47 am »
What about some light bulbs as a load?
kagem
« Reply #6 on: June 09, 2006, 10:46:28 am »
Actually, it doesn't get power from the power supply itself, it's just wired through the power supply.  I want to keep it that way so I don't have to rewire it and swapping in a jamma board will be easy.
kagem
« Reply #7 on: June 09, 2006, 10:48:52 am »
I was thinking of doing that also, but I figured a resistor will be smaller and won't heat up the cab as much.
Ken Layton
  • Guru
  • Technician
« Reply #8 on: June 09, 2006, 11:12:26 am »
10 watts isn't enough heat dissipation for that resistor. You'll find it gets real HOT real fast! Here's exactly what you need at Mouser Electronics (www.mouser.com):
# 588-L50J-1.0     Ohmite fixed vitreous enamel power resistor, 1.0 ohm, 50 watt
It's only $7.18 for it and is the proper one to correctly load the 5 volt line on the power supply.
kagem
« Reply #9 on: June 09, 2006, 11:23:12 am »
Actually, I think it's enough, since there are two of them.  At 2 ohms, you get 12.5 watts of power and since there are two, each only have to worry about 6.25 watts.  I'm not exactly skilled in this, but I did look it up and most people say that when two resistors are used in series you double their power rating, as long as you use two identical resistors.
« Last Edit: June 09, 2006, 11:28:09 am by kagem »
SirPeale
  • Green Mountain Man
Re: Using a resistor to provide load on the power supply. *updated*
« Reply #10 on: June 09, 2006, 08:08:36 pm »
I can't believe the amount of trouble you're going thru.  Just rewire and be done with it.
