Author Topic: Compiling Mame With VC++ Express  (Read 2467 times)
arcadegamenut
  • Last login:July 16, 2010, 01:48:45 pm
« on: June 05, 2006, 02:40:45 pm »
I have VC++ Express with the platform SDK and DirectX SDK.
I downloaded VCMame 105 and the Mame105 source code
Extracted mame source to a directory. Extracted VCMame source to same directory allowing the overwrite of the two files (patch).
Opened the project solution in VC++ 2005 and allowed it to perform its conversion.
Changed the project settings for C code generation to be multi-threaded with debug to avoid library errors when compiling romcmp.
So everything goes fine until it gets to vcmame. I end up with 88 errors along the lines of
'verboselog' : too few arguments for call
I've read through this board and mameworld (the only place where vcmame is talked about) and I didn't see anyone else getting this error, so obviously, I've missed something somewhere.
Anyone know what?
Buddabing
Re: Compiling Mame With VC++ Express
« Reply #1 on: June 05, 2006, 02:47:37 pm »
Why not just compile with MinGW? Are there features in VCMAME that are not in regular MAME?
Please read the wiki!
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
« Reply #2 on: June 05, 2006, 03:06:03 pm »
Yeah, Visual Studio's debugging power.
I'm going to be trying this soon as I am just fed up with debugging mingw.
arcadegamenut
« Reply #3 on: June 05, 2006, 05:00:13 pm »
@Buddabing
I don't think there is anything along the line of new features...it's just mame. But as Poonga mentioned, there is the advanced debugger. I also like the IDE with the intellisense along with other features that make looking through the project much easier.
Someone (I think on Mameworld) posted that they had received a very very slight increase in speed for some games.
@SirPoonga
Hmm...I thought I already read where you had tried it about a year or so ago. I think I saw someone mention on the mameworld board that they had compiled successfully so I must be missing something. I may have to sign up for a new user (I forget my old one there) and post my message there as well.
SirPoonga
  • Puck'em Up
« Reply #4 on: June 05, 2006, 06:06:46 pm »
I tried it some time ago just before it went unsupported.  But since it is being made again I gotta give it a try.
youki
  • Last login:October 12, 2025, 12:33:39 pm
  • Atomic Front End Creator
    • Atomic Front End
« Reply #5 on: June 06, 2006, 03:58:29 am »
I use to compile MAME with Visual C++ 2003 , i don't have any problems. (using VCMAME source).
The only thing  is that you need to have nasm on your machine.
therefore i never tried with VC++ Express.  I had tried to compile Atomic with it, and never succeeded. :(
@Buddabing
Totally agree. VC++ debugger is really great , the IDE very user-friendly.  For me it is  lot of more confortable that using Mingw environement i tried before.
arcadegamenut
« Reply #6 on: June 06, 2006, 08:54:32 am »
I did post on MameWorld and received a link to a thread with the answer. The answer here actually wasn't the answer though. :) Still, it pointed me in the right direction.
In armcore7.c, there is a line that read:
#define VERBOSELOG verboselog
I changed it to this:
#define VERBOSELOG(x) verboselog x
So now it compiles, but has some trouble linking. I'll probably post a follow-up on MameWorld too later today.
arcadegamenut
« Reply #7 on: June 06, 2006, 01:09:05 pm »
It's working now!
Thanks to Krick for his help.
To see the last part check here:
http://www.mameworld.info/ubbthreads/showthreaded.php?Cat=&Number=76712&page=0&view=expanded&sb=5&o=&fpart=1&vc=1
