Author Topic: Give me ideas for mounting TV screen  (Read 1424 times)
lettuce
  • Make It So!
« on: May 30, 2006, 05:23:10 pm »
I have build a Ultimate Arcade Cab ( http://www.retroblast.com/reviews/ultimate_arcade.html ), and shall be using a 28" TV in the cab, i will be taking the TV out of the case, as it has stereo speakers on the side and would not fit inside the cab, so shall remove the screen and board from the TV case. At the moment i think of having MDF battons on the inside of the cab and then bolt the TV screen via its frame in the 4 corners to the batton, would this work?? Can you guys give me some ideas on how the hell im going to mount the screen in this cab?? thanks
« Last Edit: May 30, 2006, 05:25:29 pm by lettuce »
