Author Topic: Question about fixed resolution...  (Read 1471 times)
DigDreams
  • Last login:March 07, 2007, 04:37:08 am
« on: May 29, 2006, 08:11:55 pm »
My main MAME machine (the one going in the cabinet I'm building) has a strange resolution issue...  When I run MAME32 everything is fine, but when I run MAME it only works on some games, others just show a blank screen.  I need to run regular MAME since my frontend uses it (3D Arcade).
I can get around this by fixing the reolution to 640x480x32 in the MAME.INI file, but I'm not sure if that is the best setting.  I works in 640x480, 800x600, and 1024x768.  Is 640x480x32 the best choice?  Are their games that need a higher resolution than 640x480?
Also, if anyone knows how to fix the auto-switching function, please let me know - obviously I'd rather let it autop-switch.  I matched all my MAME32 settings in the MAME.ini, but it still dies on about half the games.  I am guessing it is using video modes my card supports but not my monitor, but I don't know why it acts different from MAME32...
As I am building a small "Bartop" cabinet first - I am using an old GoldStar 15" CRT monitor with a Vodoo 3000 AGP card if that helps at all...
Any help would be appreciated!
Thanks,
- DigDreams
SirPeale
  • Green Mountain Man
Re: Question about fixed resolution...
« Reply #1 on: May 29, 2006, 08:57:50 pm »
That's likely your problem right there.  Force your resolution to 640x480.  Your monitor likely doesn't support higher res.
If it does, you have other issues.
DigDreams
« Reply #2 on: May 29, 2006, 11:04:20 pm »
If I force the resolution it works fine in 640x480, 800x600, and 1024x768.  Which is best to use?  Are there any games that require more than 640x480?
SirPeale
« Reply #3 on: May 30, 2006, 09:07:24 am »
Ah, I gotcha.  I wouldn't go any higher than 640x480.  Less if you can.  Medium res is something like 400x300 or something, and standard is 320x240.  These are approximations, of course.
