Author Topic: Mounting a 49-Way, which way?  (Read 1335 times)
lettuce
  • Make It So!
« on: May 29, 2006, 12:02:31 pm »
Which way round should a Midway 40-way stick be mounted, as i think ive made a big mistake
Timoe
  • Team-Oh-tAy-Oh
    • Rattlin' Trash
Re: Mounting a 49-Way, which way?
« Reply #1 on: May 29, 2006, 12:41:17 pm »
"Note:  The 49-way Joystick MUST be mounted with it's pin connector to the left when viewed from above."
This is taken from the GGG instructions that come with the GPwiz49.
lettuce
  • Make It So!
« Reply #2 on: May 29, 2006, 01:21:13 pm »
Great, ive mounted the stick so the IDE connector is at the top when looking from above! Would it be possible to unscrew the bottom section of the 49-Way stick and rotate the circuit board so the IDE connector is on the left and then screw it back to the stick??
mccoy178
  • Trade Count: (+9)
  • Go Bucks!
« Reply #3 on: May 29, 2006, 02:01:49 pm »
I do believe someone has done that.  I thought I read a thread about that not so long ago.(A month maybe?)
Timoe
  • Team-Oh-tAy-Oh
    • Rattlin' Trash
« Reply #4 on: May 29, 2006, 03:10:21 pm »
Do a search
lettuce
  • Make It So!
« Reply #5 on: May 29, 2006, 04:03:08 pm »
I did a search but couldnt find anything
Moby Ick
  • Last login:February 12, 2007, 12:41:24 pm
« Reply #6 on: May 30, 2006, 12:31:32 am »
Yup. Very easy. just unscrew and rotate. No problem.  The mount is rectangular, so being able to rotate it allows a variety of installation options as well.
