Author Topic: Mamewah menu music issue  (Read 1274 times)
MrQuan
  • Last login:October 30, 2008, 03:47:14 am
  • Well, at least you threw a punch...
    • Tilt Arcade - Check it out!
« on: May 27, 2006, 09:15:13 pm »
I've been using MameWah as my arcade menu system since day one and find it has been very robust and reliable  :)
I have however noticed a small issue with music playback when browsing the menu.  It's all set up correctly, I put my MP3s in the Music directory etc and it finds and plays them... but sometimes MameWah will skip to the next track prematurely, before the track has ended.  Usually the 'Alt' key needs to be pressed to skip to the next track, but I'm getting this problem without any input at all.
It happens at random times during the track too, some very soon, and some halfway etc.  It's not a problem with the MP3s themselves, because MameWah usually plays them all the way through.
I understand this issue I'm having is very sporadic  :-\  Has anyone else experienced this issue, is there a known fix?
Edit: I'm running P4 1.6GHz, 512MB RAM, WinXP SP2 (hidden), Mamewah 1.6+ (as shell), Audigy 2 ZS Plat. Pro soundcard.
« Last Edit: May 27, 2006, 09:25:05 pm by MrQuan »
Re: Mamewah menu music issue
« Reply #1 on: May 30, 2006, 06:45:23 am »
I haven't seen this problem before.  All I can really think is to check your MP3's and ensure the track length in the tag is correct...I have had mp3's in the past which have had a tagged length shorter than the actual length - this could cause what you describe...
Also try disabling the 'NEXT_TRACK' shortcut (just remove the DIK_LALT or whatever, just in case.
