Author Topic: 4-player control panel help  (Read 4175 times)
Jim Persoleo
« on: April 08, 2002, 03:36:13 pm »
My control panel will be separate from the main cab and I want to put together a 4-player panel. Any ideas on specs? total length? distance between sticks and buttons?
My orginal thought was to go with 4 sticks, 8 buttons each with a start and coin button (10 buttons total)
Might drop the buttons on the outside 2 controllers since I don't htink many 4-play games have tons of buttons
Lately been thinking that not many games are 4-player (the one I most play is NFL Blitz 2000 - a PC game) so I'm not sure if it's worth the effort to design a 4-play panel and then use a secondary panel with a spinner, trackball, 4 + 8-way stick and a few buttons.
Thoughts, ideas, help would be appreciated.
Thanks,
Jim
chris falco
Re: 4-player control panel help
« Reply #1 on: April 08, 2002, 05:06:20 pm »
on my control panel. I've got 4 players, player 1 and 2 get 6 gameplay buttons, and 3 and 4 each get 4.
it's set up so from right to left it looks like
player 3,                               Player 4
             Player 1,  player 2,
I've got 4 white start buttons with the 1-4 player logos on them, and I also have them in order 3, 1, 2, 4
that way for 2 player games, the players are in the middle.
also my player 3 and 4 are slanted a little like in this pic
<a href="http://roms2.mame.dk/cab/simpsons.png" target="new">here</A>
jaydog
« Reply #2 on: April 08, 2002, 05:24:43 pm »
I have been thinking fo building a 4 player cab myself, but i got to thinking that the cab might be a little to big in order to make the games comfortable and not cramped. the solution, i'm going to build a regular 2-player cab and have players 3 and 4 use usb game pads  like microsoft sidewinder.
granted it is not totally "acrade feel" authentic but can you honesty say you are going to have enough 4player NBA JAM sessions to justify building an entire 4 player control panel.  a two player cab with two usb joypads is much more economical and it keeps your cab Pritty looking.  most of my friends preferr playing with a game pad anyway.
Jim Persoleo
« Reply #3 on: April 09, 2002, 09:12:19 am »
I think I'll go to the 2-player panel but put the trackball, spinner and 4-ways all on that. Then either go with jaydog's suggestion and use a pair of usb gamepads or build a small 2nd panel for 3rd+4th players.
Although to be honest I have access to a free play NFL Blitz/NBA Jam machine and I have yet to find a game pad that comes close to a joystick for those 2 games (any suggestions?) I use a gravis game pad pro and it sucks for Blitz and Jam on the PC. Getting used to it on Tony Hawk - just wish it did the main 4 directions easier (like the old PS ones did)
I came to the conclusion that I'll be playing solo or with just one other mostly and the 4-player fests will be rare (about every month when the guys come over for the LAN party). Thanks again for the help. Now to harrass some local woodworkers.
Lilwolf
  • Last login:June 08, 2026, 09:58:06 am
« Reply #4 on: April 09, 2002, 11:25:21 am »
Really look at having hotswap control panels.
then you can build them as you want.
4way with 4 buttons
2way with 10 buttons
8way flight + trackball + buttons
starwars yoke
ie, you can add when you want.  If you go with a keyboard encoder, they all handle hotswapping.  Also, for the trackball and analog hacks... If you go with a usb solution, you have hotswap for them also.
Lilwolf
« Reply #5 on: April 09, 2002, 11:26:31 am »
ok... try this again
4 - 8way, 4 buttons
2 - 8way, 10 buttons
then another great one
1 - 4way then the buttons for asteroids, then a qbert 4way.
jerryjanis
  • Last login:September 10, 2026, 01:23:41 pm
  • Skate or Die!!!
    • Jake's Joystick
« Reply #6 on: April 09, 2002, 12:46:44 pm »
Just curious...  But why 10 buttons?  For PC games, maybe?  Are there any MAME games that would require 10 buttons?  My impression right now is that 6 buttons are plenty for player 1 or 2 (Street Fighter), but apparently I'm wrong.  I know that MAME can deal with 10 buttons, but I don't know what that's for...?
BASSOFeeSH
  • Last login:May 29, 2009, 12:46:42 am
  • TD-2779
    • Trooper Armor
« Reply #7 on: April 09, 2002, 01:57:08 pm »
For console games perhaps?
Frobozz
  • Last login:November 15, 2002, 03:16:45 am
  • I've been sane, but then I got better.
« Reply #8 on: April 09, 2002, 02:02:06 pm »
Hmm... PSX controllers have 10...   4 pad buttons, 4 trigger buttons, start / select buttons.
Add 2 more if you count the R3 and L3 "click the dual-shock stick" buttons.
