Author Topic: Alternative to slot cutter for T-molding  (Read 2854 times)
beaver24
  • Last login:June 02, 2006, 09:38:02 am
« on: May 23, 2006, 08:37:43 pm »
After looking all over the place for the slot-cutter router bit to route for t-molding I found a cheap alternative. I was looking around my garage and noticed the little 5 3/8" circular saw that came with my cordless drill kit which I have never used b/c the battery dies too quick. I noticed the blade was really narrow, measured it and sure enough it was 1/16". Ran it across a scrap piece of MDF and T-molding fit perfectly. Made a jig for the saw set the depth and ran it across the edge of my cp it worked perfectly. Just figured I'd mention it in case some of you have that saw they have never found a good use for.
Re: Alternative to slot cutter for T-molding
« Reply #1 on: May 23, 2006, 11:27:31 pm »
Thats some good advice! It's not the slot cutter thats expensive, it's the combination of bits and a router. So, if someone has these tools it could indeed save them some money for potentially a 1 use tool.
Any chance you can post some pics of the jig?
djll
  • Last login:September 28, 2009, 04:26:13 pm
« Reply #2 on: May 24, 2006, 12:39:08 am »
Does anyone have an online link for purchasing the router bit to route tmolding? TIA.
Gh0sty
  • Last login:November 17, 2025, 03:43:45 am
  • flying Mame Player
« Reply #3 on: May 24, 2006, 04:22:06 am »
hey beaver24 ive done the t-molding the same way you done it with a very good result on
my external CP.
R
Gh0sty
Quarters
  • Last login:July 08, 2010, 06:53:17 pm
  • I am not now, nor have I ever been, a llama!
    • Quarters Arcade Site
« Reply #4 on: May 24, 2006, 07:46:33 am »
There are better bits out there, but this one from tmolding.com works fine.
97.4 percent of all statistics are full of crap.
beaver24
« Reply #5 on: May 24, 2006, 08:33:13 am »
I know the bits work perfectly, but I assumed other people may have the same thing I did. I got that saw with my drill and never used it. It was kinda a throw in tool with the kit, its nice to be able to use tools you already have and aren't using. They throw those in with all the cordless kits, just a suggestion.
Quarters
« Reply #6 on: May 24, 2006, 08:36:42 am »
just a suggestion.
and a good one. I was responding to the question by apemanttt.
PCtech
  • BYAOC is kinda like methadone
  • Last login:December 07, 2019, 09:58:57 am
  • If the magic smoke gets out, it won't work again!
« Reply #7 on: May 24, 2006, 08:43:11 am »
My local Lowes had the slot cutter bit....good luck!
Example of what NOT to say at BYOAC
"a working adult playing a video game - pathetic" - freddykruger666
meany
  • Last login:May 01, 2019, 02:12:23 pm
  • Atomic batteries to power, turbines to speed....
« Reply #8 on: May 24, 2006, 09:31:10 am »
$16
http://www.mlcswoodworking.com/shopsite_sc/store/html/smarthtml/pages/bt_slot.html#Anchor%20slotct3w
beaver24
« Reply #9 on: May 24, 2006, 10:33:48 am »
Sorry quarters didn't realize you were answering the other post
djll
« Reply #10 on: May 24, 2006, 11:08:13 am »
my external CP.
R
Gh0sty
Ghosty, what type of surface is that on your CP?
