Author Topic: Anyone ever tried a 4:3 HDTV?  (Read 2394 times)
Duster72
  • Last login:October 27, 2006, 08:25:52 am
« on: May 22, 2006, 01:44:41 pm »
I just noticed this Insignia TV at Best Buy:
Link
It's 4:3, but it displays up to 1080i.  This would be perfect for me, because I could run my Xbox/PS2/Gamecube over component video, and the XBox has several 720p titles.
My question is about passing video from the computer over component video or DVI.  I currently have an ATI Radeon 9550 and could buy a component video adapter.  Should I do that, or should I get a DVI-HDMI cable?  Would that work?  What resolution can I output to look the best on that monitor?
Any help would be appreciated.
« Last Edit: September 28, 2006, 08:31:14 pm by Peale »
Hudson187
  • Last login:August 20, 2013, 10:05:28 pm
Re: Anyone ever tried a 4:3 HDTV?
« Reply #1 on: May 22, 2006, 04:56:54 pm »
Just incase you didnt know, 720p and 1080i will display in widescreen. I have a 40" Sony XBR 4:3 Tube tv and whenever I go into those 2 resolutions with my xb (or my 360) they go into widescreen mode. So, it will display 16:9 in a 4:3 display.
mhermann
  • Last login:October 04, 2019, 07:10:08 pm
  • We ain't found.........
« Reply #2 on: May 31, 2006, 09:38:49 am »
So did you try it? How would a PC image display on this? Would this be a good PC monitor?
I am wondering if connecting a pc would force it to widescreen or not. May have to buy one to see. I think Bestbuy has a 30 day return policy.
« Last Edit: May 31, 2006, 10:51:47 am by mhermann »
Hudson187
« Reply #3 on: May 31, 2006, 09:47:34 pm »
I hooked my computer up for the hell of it to my tv via component. 480i dispalyed in full 4:3... while 720 and 1080 forced widescreen.
Harry Potter
  • Smite-bait
  • Last login:May 27, 2024, 03:33:28 am
  • Sober until banned. Can post but still can't read.
« Reply #4 on: June 02, 2006, 07:14:48 am »
If you pass it through the HDMI (Using a DVI to HDMI converter $$$), you'll get very close to native resolution (As native as you can get on a tube telly).
Through HDMI it shouldn't go widescreen but there should also be a setting on the TV itself to force all signals into 4:3
Now in a tasty new flavour.
Duster72
« Reply #5 on: September 28, 2006, 07:32:38 pm »
Okay,
So I bought the TV (I know, it was a couple months ago that I asked this).  It's a Insignia NS-27HTV.  I had some extra home theater stuff laying around, so I used a DVI-HDMI cable and have the PC hooked up via HDMI.  It worked immediately, which made me happy.
Now on to the problems:
1) I have a really bad flicker.  I am thinking it has something to do with the refresh rate, I don't know.
a) I have the ATI set up for a flat panel display.  It reads the TV as a 800x600 1080i flat panel
b) I set it to 60Hz
c) It let me change the resolution once and I tried a high resolution, but the fonts were too small, so I cancelled it and now it won't let me change the resolution anymore
2) I have really bad overscan -- I can't see the start menu logo or anything in the system tray.  Is this a problem with the display or the video card???
I really need some good help here, guys.  If I can get Windows working correctly it seems like the rest wouldn't be too bad.
The good news is that I'm running HDMI!  Pretty awesome, IMHO.
Duster72
« Reply #6 on: September 28, 2006, 08:03:00 pm »
I think the problem is that the ATI software is forcing me to run 720x480.  I have to enable stretching in order to get anything big enough to see.
So how do I get the stupid ATI software to allow me to chage the resolution of a FPD.....
