Author Topic: Monitor and chassis help  (Read 1603 times)
rfr341
  • Last login:May 24, 2017, 12:15:31 am
« on: May 20, 2006, 01:24:31 am »
Hi I was wondering if I get a wells gardner 7000 series medium resolution chassis will it work with a RCA 19VLTP22 tube that right now has a standard resolution chassis connected to it or  would I  have to change the yoke on the tube so the that medium resolution chassis  would work with the tube. Would the pins on the yoke be the same?
Ken Layton
  • Guru
  • Technician
Re: Monitor and chassis help
« Reply #1 on: May 20, 2006, 01:37:50 am »
If you use a medium resolution chassis then you must also use the correct medium resolution yoke with it. A medium res yoke works much harder than a standard res one does.
rfr341
« Reply #2 on: May 20, 2006, 02:05:43 am »
Thanks Ken for the info. I was wondering what you think of the neotec trisync 19" monitor, is this monitor any good. Is there some where you would recommend getting one from it is worth buying.I need a medium resolution monitor for my Atari A.P.B game.
