Author Topic: Genesis Emulation, multiplayer troubles.  (Read 1874 times)
JonnyBoy
  • Last login:November 12, 2009, 01:59:00 pm
  • Inka Dinka Do
« on: May 14, 2006, 04:32:58 pm »
Hey guys,
I finished my project and am working on setting up the software. I have SNES, NES, and the like up and running smoothly, but I am having a problem with Genesis emulation.
The two best emulators, from what I read, are Gens and Kega (Now Fusion). But when I tried both of these emulators, two players would cause certain shortcuts to go off and load up menus and stuff that I don't want to load up. How can I avoid this? They are standard MAME controls.
An example would be, when a friend and I play, randomly a screen will pop up prompting us to load a save state or Rom or something.
Thanks for the help.
I had to beat them to death with their own shoes...
Brad
  • Last login:August 03, 2018, 05:43:23 pm
    • www.emuchrist.org
Re: Genesis Emulation, multiplayer troubles.
« Reply #1 on: May 14, 2006, 05:15:22 pm »
Remap the controls in Fusion
Brad
Rip
  • Last login:September 26, 2008, 05:28:16 pm
  • Product of the 80s
    • Curret lineup
« Reply #2 on: May 14, 2006, 05:31:36 pm »
What kind of kb encoder did you use?  If it is a straght kb hack, or a cheap kb encoder, you might be experiencing keyboard ghosting.
http://arcadecontrols.com/arcade_input.shtml#KeyboardGhosting
You may only see it in the genesis emulators because of the emus choice for menu shortcuts.
John
Recreating the 80s, one cab at a time.
Gallery
JonnyBoy
  • Inka Dinka Do
« Reply #3 on: May 14, 2006, 05:57:23 pm »
I'm using an IPAC, standard configuration.
When I remap the keys in Fusion, it still sets off those shortcuts, because they are macros in the software itself and there is no option to turn them off...
Thanks for the responses.
« Reply #4 on: May 15, 2006, 05:07:26 am »
I don't have this problem...Fusion is very cabinet friendly.  Make sure you have the latest version and make sure you run it with the -fullscreen switch.  If you run in a window I can see using the 'Alt' key would almost certainly cause problems.
JonnyBoy
  • Inka Dinka Do
« Reply #5 on: May 15, 2006, 07:22:33 am »
Yeah, I'm going to try remapping that key.
« Reply #6 on: May 15, 2006, 11:40:59 am »
Well just to add...I use Alt with Fusion with no problems...all I can think is the -fullscreen switch as I say.
