Author Topic: [AtomicFE][Updated]new ENHANCED plug'n play Arcade Module!  (Read 1864 times)
youki
  • Last login:October 12, 2025, 12:33:39 pm
  • Atomic Front End Creator
    • Atomic Front End
Hi All ,
A new module is online.
This one  called ArcadeEnhanced ,  use the same emulators than the other one. (MAME , Zinc, modula2)  , and as the other choose the best emulator to run.
But this module, allow you to select game by all categories you want.
A automatic generator is provided.  Just put your roms in the right folder. And Run the generator , then run Atomic  and you will be able to select your games by all kind of category.  And of course, the generator is customizable is you need.
Don't forget to read  the readme file before using this module
avaibable on http://www.atomicfe.com
« Last Edit: May 12, 2006, 05:18:10 am by youki »
Havok
  • Trade Count: (+17)
Re: [AtomicFE]new ENHANCED plug'n play Arcade Module!
« Reply #1 on: May 10, 2006, 01:04:31 pm »
Nice!
So, when can we expect that new layout editor?
youki
    • Atomic Front End
« Reply #2 on: May 11, 2006, 04:16:07 am »
The layout editor is ready. :)
But now, i'm currently working on Atomic itself to support the new enhanced layout format.
I hope being able to provide the next version at the end of this month.
youki
    • Atomic Front End
« Reply #3 on: May 12, 2006, 05:17:39 am »
Module Arcade+  Updated.  I fixed a big BUG.  The module didn't work if the module Arcade (normal one) was not installed before.  Now, the module Arcade Enhanced can work alone.
