Author Topic: Keywiz help needed  (Read 9240 times)
emerica
  • Last login:September 18, 2024, 09:27:07 pm
  • Goodtimes!
    • My ongoing projects
Re: Keywiz help needed
« Reply #40 on: May 12, 2006, 12:49:54 pm »
The white stuff you are referring to is probably white lithium grease and IMO not recommended for what you want to use it for. White lithium is good for metal pats that rub together and the stuff can be a little messy.
Silicone spray is clear. It will say silicone spray on the can.
I saw the best minds of my generation destroyed by madness, starving hysterical.
kiddk1
  • Last login:August 01, 2022, 10:58:08 am
  • HAP KI DO
« Reply #41 on: May 12, 2006, 01:03:39 pm »
you are correct, the furniture polish fozzy was referring to, is that something like murphys oil soap?
Its easy to like someone,
If you dont know them very well.
emerica
  • Goodtimes!
« Reply #42 on: May 12, 2006, 08:32:22 pm »
that might work although I do not have any experience with it
Fozzy The Bear
  • Handbags at dawn in here!!!
  • Last login:September 18, 2011, 11:29:59 am
  • It's Been One Of Those Days... Don't Ask!
« Reply #43 on: May 14, 2006, 02:23:51 am »
I can't give you brands.... I'm on the other side of the Atlantic.... Just look for something that says silicone wax polish and olny use a very very very small amount.
The worst thing you can end up with is a sticky surface. You really want to avoid that. A very clean dry mech is the the best thing of all.
Best Regards,
Julian (fozzy The Bear)
Most bottles and jars contain at least twenty-five percent recycled Pacman.
And research indicates that Space Invaders are strongly attracted to people who have recently eaten meat pies.
kiddk1
  • HAP KI DO
« Reply #44 on: May 14, 2006, 10:32:08 am »
thanks
