Author Topic: Electric Ice pusbuttons question..  (Read 1405 times)
method
  • Last login:October 12, 2007, 11:41:09 am
« on: May 07, 2006, 09:44:25 am »
I'm pretty new to this and had some questions bout running pushbuttons with LED's.
I'm probably gon go with a set of electric ice pushbuttons but the thing is i aint got a clue on how to run em, been lookin around and cant find anything clear enough to freakin understand, and what i wanted to know is to run these do you require any other bits and pieces to go along wit them? Like this for example http://groovygamegear.com/webstore/index.php?main_page=product_info&cPath=73&products_id=240.
And yeah this might seem like a stupid question and im sure it is but what would you's reccomend to power the LED's?
« Last Edit: May 07, 2006, 10:04:39 am by method »
MYX
    • MYX Digital Blog
Re: Electric Ice pusbuttons question..
« Reply #1 on: May 07, 2006, 01:18:22 pm »
This is where some knowledge will be useful. If you do not know what you are doing you could blow up your computer and I am just speaking for myself, but that would be a bad thing. A lot of us you's the voltage from a lead in the computer. LEDWiz will run them and it takes the voltage from the USB line. You could get a small power supply and run em with that. Or most simply use a 9 volt battery with 470ohm resistors. The resistance is dependant on the voltage and the LEDs them selves. Do a search on that topic. It has been discussed a number of times.
M    Y    X
method
« Reply #2 on: May 08, 2006, 12:38:07 am »
rite thanks for that, ill probably pick up one of those LEDWiz, looks like it'll do the job
method
« Reply #3 on: May 08, 2006, 11:16:43 am »
edit: found an answer to this question
« Last Edit: May 08, 2006, 12:20:46 pm by method »
