Author Topic: frontends display resolution question  (Read 2571 times)
kiddk1
  • Last login:August 01, 2022, 10:58:08 am
  • HAP KI DO
« on: May 06, 2006, 03:26:37 pm »
I have tried 3 diff frontends(mamewah, gameex, and atomic)  all 3 display fine on my screen but once I launch a game the size is decreased.  I cannot figure this out.  I included an example of 1942, the black on the sides is the rest of my screen.  any help would be appreciated
Its easy to like someone,
If you dont know them very well.
  • Last login:May 05, 2026, 10:44:49 pm
Re: frontends display resolution question
« Reply #1 on: May 06, 2006, 05:17:47 pm »
Dude, that's a vertical game, it's not supposed to fill the entire horizontal width of the screen.  Also having artwork, crop turned off is what is making the screen so tiny.
kiddk1
  • HAP KI DO
« Reply #2 on: May 07, 2006, 10:44:38 am »
I understand its a vertical game, but street fighter displays the same way.  where is artwork crop located in gameex?  thanks
« Reply #3 on: May 07, 2006, 11:58:36 pm »
it's a mame setting
set it in mame's mame.ini
kiddk1
  • HAP KI DO
« Reply #4 on: May 08, 2006, 07:56:23 pm »
I am using gameex which is where the snapshot was taken from
« Reply #5 on: May 09, 2006, 04:12:11 am »
it's a mame setting
kiddk1
  • HAP KI DO
« Reply #6 on: May 09, 2006, 10:15:45 am »
sorry i didnt realize you said mame. i will check the mame.ini
just checked, I am running mame105 and did not see a mame.ini file.  where is it located?
« Last Edit: May 09, 2006, 10:32:51 am by kiddk1 »
« Reply #7 on: May 09, 2006, 11:43:02 am »
You need to create one: www.mameworld.net/easyemu
kiddk1
  • HAP KI DO
« Reply #8 on: May 09, 2006, 01:54:54 pm »
a little beyond me for now
Denverlatino
  • ---Buyer Beware - transactions with this user are in dispute--- ... Banned ...
  • Last login:May 13, 2009, 02:55:24 pm
« Reply #9 on: May 09, 2006, 04:55:44 pm »
actually i have the same problem but with the games only, i have mame resolution  to auto and the game comes small, and if i specify a resolution too what's on my computer (like 800x600) the games came the same way .....small.....how do i make then fill out the screen... i know if i have a horizontal monitor horisontal games should fill the scree and vertical games should have black lines on the sides, but if i have a vertical monitor shuold vertical games fill the screen as well? thanks for reading
[transactions in dispute -- see http://forum.arcadecontrols.com/index.php?topic=77030.0]
... Banned ...
« Reply #10 on: May 10, 2006, 04:37:17 am »
Typing 'mame -cc' is beyond you?  If took more effort than that to write your posts in this forum...
« Reply #11 on: May 10, 2006, 04:37:52 am »
Try using hardware stretch (hwstretch).
kiddk1
  • HAP KI DO
« Reply #12 on: May 10, 2006, 09:36:57 am »
let me be more clear, creating a mame.ini file is beyond me.   why not stop being such an ass and be more clear.  where do I type mame -cc?
Congui
  • Last login:July 23, 2015, 12:54:53 pm
  • Newbie!
« Reply #13 on: May 10, 2006, 11:48:53 am »
You type 'mame -cc'  where your mame.exe is located.
Havok
  • Trade Count: (+17)
« Reply #14 on: May 10, 2006, 11:51:41 am »
I am having a moment of charity - it won't last long, but let me help you out before the guys here slam you (and rightfully so).
You need an .ini file to specify mame settings you would like to change, or it will use the defaults: one of which is to add artwork and not use hardware stretch. These are MAME settings - it will affect ALL the frontends, since all they do is launch MAME.
You need to check out the link that Minwah provided, it will tell you everything you need to know, you just have to READ it, but you must put forth some effort on your side - it's the only true way to learn this stuff.
To create the ini file (using mame -cc), they mean open a command prompt and while in the mame directory, type that command in. You will then have a brand-new mame.ini file, which when opened with a text editor, like notepad, you can change the settings, most of which are 0 if off, 1 if on.
To learn more, try this link - it's drilled down a little more than Minwah's:
http://www.mameworld.net/easyemu/mameguide/mameindex.htm
Click on the config files to the left.
Now get reading and get that fixed!
« Reply #15 on: May 10, 2006, 11:54:04 am »
God I'm very patient but this has pissed me off today.  If you can't be arsed to follow the link I gave you a simple search of this board or any mame-related one would find the answer about 5 billion times.
kiddk1
  • HAP KI DO
« Reply #16 on: May 10, 2006, 01:08:21 pm »
Thanks guys, i will get cracking.
