Author Topic: arcade vga do i need a jpac  (Read 2241 times)
BombProofPlane
  • Last login:February 11, 2009, 04:14:14 pm
« on: March 01, 2003, 08:19:51 pm »
im getting a jamma cab with a 25" arcade monitor
do i need a jpac or can i just hack a vga cable
how would i connect a hacked vga cable to a arcade monitor
Cave
  • Last login:June 07, 2009, 10:27:58 am
Re:arcade vga do i need a jpac
« Reply #1 on: March 02, 2003, 08:18:10 am »
If you don't get a j-pac you will have to hack a lot more than the vga cable, all the inputs for the controls will have to be cut from the jamma loom.
Using a j-pac it simply plugs into the keyboard&vga connectors on the computer and connects to the jamma fingerboard interfacing them all without the need to hack anything, thus leaving your jamma cab intact incase you want to use real pcb's.
