Author Topic: Clrmame auditing  (Read 1571 times)
hypernova
  • Last login:November 25, 2016, 12:52:48 pm
Clrmame auditing
« on: May 02, 2006, 08:00:25 pm »
I downloaded my roms off emule.  Deciding to try and contribute to [romsite name redacted] without redownloading all 15 GB or whatever, I want to audit my roms and join in so I don't have to upload as much to stay on the good side of the admins there.  So is it normal to take hours to audit the roms based on mame .105 using a 3.2 ghz processor system?
Just a quick check of the process:
15587 matched | 16298 created | 78 skipped
It was around 25% done, in the F section (fatal fury) when i took those numbers.
Never having used clrmame before, is this normal?  I tried reading [romsite name redacted]'s pdf and clrmame's help files, but it's all just so darned confusing. :dizzy:  Please tell me this is normal.
« Last Edit: February 05, 2015, 02:00:15 am by PL1 »
I'll exercise patience when you stop exercising stupidity.
My zazzle page.  I've created T-shirts!
Hiub1
  • Last login:June 05, 2011, 11:43:25 am
  • www.sleepyjack.com
Re: Clrmame auditing
« Reply #1 on: May 02, 2006, 08:03:49 pm »
Did you rebuild the roms, or did you scan them? It should take a good while, I know my roms did and I am on a Sempron 3200.
SirPeale
  • Green Mountain Man
« Reply #2 on: May 02, 2006, 10:39:34 pm »
Scanning doesn't take that long, BUT...
You won't easily be able to share what you have with the [romsite name redacted] folk, unless you use RomTorrent. (I think that's what it's called).
It'll unzip and make the ZIP file exactly to what everyone else is using.
This will take a *very* long time to do.
Not saying you shouldn't do this, but if you want to share, share the CHDs.  They're exactly the same from person to person, no modification necessary.
« Last Edit: February 05, 2015, 02:01:10 am by PL1 »
Hiub1
« Reply #3 on: May 02, 2006, 10:45:16 pm »
The name of the app is TorrentZip, and it really is reccomended that you use that program if you are going to be on [romsite name redacted], as it will save you lots of bandwith by already starting with part of the torrent if you don't have it all.
« Last Edit: February 05, 2015, 02:01:33 am by PL1 »
