Author Topic: Need Help with Asteroids Monitor Issue  (Read 1369 times)
fast911rs
  • Newbie
  • Last login:April 29, 2006, 03:33:45 pm
« on: April 29, 2006, 03:14:25 pm »
I am fairly new to arcade games. I have a Asteriods game that I recently bought that only shows a bright verticle line down the center. I checked the two fuses on the PCB board, both fine. Is this a monitor issue, PCB issue or ..... ???? Any way to troubleshoot? Any help would be appreciated. If a monitor or PCB problem, is it posssible to find replacements? I saw a couple posts about a monitor that might work.
Thanks - Ryan
« Last Edit: April 29, 2006, 03:17:21 pm by fast911rs »
D_Zoot
  • Last login:November 18, 2010, 03:59:37 pm
  • Sorry if I get any spit on you...
Re: Need Help with Asteroids Monitor Issue
« Reply #1 on: April 29, 2006, 03:33:00 pm »
Ryan,
Is there still a sticker on the monitor that identifies it?  It could be an Electrohome GO5-801 or an 802 (it could also be a Wells-Gardner if somebody replaced it, but not likely).
One or two possibilities,  first is a deflection problem with the monitor.  Usually it's caused by failed deflection transistor(s) for the monitor deflection board or bad solder joints.   Next would be a game board problem.
Does the game coin up and make sounds like it's playing?  Can you put the game into test mode and listen for beeps?
If you can post back with a little more info we can probably help you to narrow it down a little more.
D
« Last Edit: April 29, 2006, 05:24:44 pm by D_Zoot »
grantspain
« Reply #2 on: April 29, 2006, 04:44:57 pm »
def a monitor prob,most likely-dry joints on the chassis,next faulty frame ic or 25v to frame ic(depends on chassis)
