Author Topic: Classics CP layout feedback request  (Read 1380 times)
Dervacumen
  • Last login:June 12, 2024, 01:58:21 am
  • Home of Three Squares dice game
    • Beaker Games
« on: April 28, 2006, 11:57:56 am »
I've only got 23.75" side to side to work with here, so although I wanted to have my buttons in a straight row or a gentle arc, it just wasn't going to happen.  My question is, is it worthwhile to add a fourth button under buttons 4 - 5 and 8-9?  It's simple enough to do, but will I get much more mileage?  I guess it could be cool for vanguard.  My worry is that the CP is already pretty tight.
The top left joystick is a 4 way, the other two are 8 way.
Actually, any suggestions are welcome.
Thanks,
Derv
Bringing to life a child's imagination.
JonnyBoy
  • Last login:November 12, 2009, 01:59:00 pm
  • Inka Dinka Do
Re: Classics CP layout feedback request
« Reply #1 on: April 28, 2006, 12:16:31 pm »
That's a tough one...
I would move the top button down just a tad bit on each side to reduce the arc a tad.
I don't know about a fourth button. Have you tried laying it out on cardboard?
I had to beat them to death with their own shoes...
MinerAl
  • Last login:December 15, 2025, 06:28:31 pm
  • duck
« Reply #2 on: April 28, 2006, 12:21:45 pm »
If you rotate 2 and 3 90o you'll gain some space to spread out your buttons a bit.
I have a similar situation on one control panel, and I find the 4-in-a-diamond button pattern very natural and useful.  We're pretty much all used to the arrow keys on a computer keyboard anyway, so that arrangement is familiar.
« Last Edit: April 28, 2006, 12:26:19 pm by MinerAl »
JonnyBoy
  • Inka Dinka Do
« Reply #3 on: April 28, 2006, 01:21:56 pm »
Yeah, I didn't even think about how the arrow keys on a keyboard are oriented.
Are you planning on putting start buttons?
Dervacumen
    • Beaker Games
« Reply #4 on: April 28, 2006, 02:29:17 pm »
These are all good points.  I did intend to rotate the joysticks to squeeze a tad more room, and even thought of decreasing from 3/4" to 1/2" the wood for the sides and back...every bit will help.  I have not mocked this exact config up in cardboard, but will do so this evening once.
I think I'll put in the 4th button in diamond config.
I have a separate panel under the monitor that holds the P1, P2, Start, Pause, and Exit buttons.  The reason is this panel will be swappable with others I intend to build later.
Most Excellent!
