Author Topic: Happs Arkanoid spinner  (Read 1490 times)
Teknique
  • Last login:October 02, 2015, 10:35:46 am
  • I'm a Gauntlet wizard in real life
« on: April 25, 2006, 08:05:09 pm »
Assuming I even wanted to spend $137 for this Arkanoid spinner, is this even something that a home arcade enthusiast as myself can hook up easily (i.e. USB or other direct connect means) or does it require PCBs and other stuff that I don't really know anything about....?
http://www.happcontrols.com/joysticks/95093100.htm
Tek
Your screen name has been added to my frag list.
markrvp
  • NFL Expert
Re: Happs Arkanoid spinner
« Reply #1 on: April 25, 2006, 08:54:07 pm »
You should be able to connect it to the computer via USB with an Optiwiz from Groovy Game Gear or by hacking a mouse.  I highly recommend getting the Optiwiz.  If you are getting the spinner for Arkanoid, go for it.  If you want a high resolution spinner that will work pretty well with Arkanoid, but also other games, then you might consider the spinner offered by Groovy Game Gear.
Kremmit
  • - AHOTW -
  • Who the heck is that?
« Reply #2 on: April 25, 2006, 11:33:05 pm »
And if you want a real Arkanoid spinner, but don't want do drop that much cash, used ones go for less on ebay (when they come up).
Teknique
« Reply #3 on: April 26, 2006, 05:59:03 am »
cool, thanks for the info guys.
Tek
